Gearing vs Tire size - JeepForum.com
post #1 of 7 Old 11-18-2006, 03:49 PM Thread Starter
MZP
I have a JK 2dr Rubi (auto)on its way with 4.10 gearing. I would like to run a 3" lift and 35's on it. Can the 4.10 handle the 35's or am I going to be faced with a sluggish vehicle and not be able to use overdrive, etc. I don't really want to regear right now. Anybody running 35's on their Jk, I would greatly appreciate your input. TJ owners also chime in. Thanks!
MZP is offline
post #2 of 7 Old 11-18-2006, 05:18 PM
SecondTJ
SecondTJ's Avatar
with the auto 4.10s should be ok
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 7 Old 11-18-2006, 05:22 PM
Laxstar46
i agree with second tj u should be fine. but u still will notice lack in performance that comes iwth putting bigger tires on but if u want to go back to stock performance then regear will be a must but if ur fine with the small bit of a loss u will have then ur good
Laxstar46 is offline
post #4 of 7 Old 11-18-2006, 05:33 PM Thread Starter
MZP
I can live with a small bit. I have read threads about loosing overdrive, not being able to pass on the freeway, etc. I am sure some of those threads weren't 4.10's though.
MZP is offline
post #5 of 7 Old 11-19-2006, 09:38 AM
IMFLASH
35's I believe need 4.56's
I had a 99 TJ with 64,000 miles and I ran 35's BFG Muds, I would take 4.56's anyday. It was a manual and a blast to drive. That is just my 2 cents
IMFLASH is offline
post #6 of 7 Old 11-20-2006, 12:26 AM
Hip2u77
You're still above the 3.21 ratio that the X and Sahara 6-speeds come with. A little more weight, and a little more rolling resistance, but I think you'll be OK.
Hip2u77 is offline
post #7 of 7 Old 11-20-2006, 04:35 PM Thread Starter
MZP
What does it cost to regear and when do you think the JK will have gears available. I am sure companies are working on these as we speak. Anybody know?
MZP is offline
Gearing to tire size chart unlimited4x4 TJ Wrangler Technical Forum 14 09-26-2008 01:33 PM
Question for tire size & gearing GDTIME TJ Wrangler Technical Forum 5 09-11-2008 10:51 AM
Another: tire size re-gearing question liquidforcedude TJ Wrangler Technical Forum 8 11-26-2007 08:36 PM
Gearing/Tire size Shawno TJ Wrangler Technical Forum 7 09-18-2003 11:43 AM
Tire size and gearing?? JeepinSC87 YJ Wrangler Technical Forum 6 04-11-2003 07:26 PM
