gear ratio for Rubicon - Page 3 - JeepForum.com
post #31 of 35 Old 09-14-2013, 09:24 AM
HOKIES2010
2011 JK Wrangler
I ran heavy 37s with 4.10s for acouple months down in flat FL. It was doable but not fun. I think 35s would doable as well but also not fun.
I run 5.13s now with the 37s. Pairs well with the manual and 3.8.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #32 of 35 Old 09-14-2013, 12:40 PM
HappyTrails
I remember running my 37's with 4.10's for a short while in the hills around NW Georgia. All I remember thinking was, "Thank God for the supercharger! This think would be absolutely unbearable." Then I put 5.38's in it and am back to being a happy camper.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #33 of 35 Old 09-14-2013, 05:21 PM Thread Starter
jenniferjeep
2010 JK Wrangler
So this got me thinking what does regearing to lower gears do to your gas milage? I would think that it is going to drop.
jenniferjeep is offline
post #34 of 35 Old 09-14-2013, 06:14 PM
JIMBOX
If you regear to one of the better ratios (5.13/5.38) your gas mileage drops drastically---at first, because it's like you gotta engine transplant (almost), but
As soon as you get over the new toy, mileage gets better-
I was able to get high 18 mpg driving 60 mph and the avg mileage driving at 70 is 16.2 and towing 14.9-
However my JKUR weighs over 2-3/4 tons when ready for a trip-so the lighter and more economically driven can show great benefits in gas mileage--
This is only for 07 to 11 JK/JKUs--because you're putting the 3.8l v6 in its happy comfort zone-- 2200/2400 rpm--
Of course, everyones different and the tire size is instrumental in these figures-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #35 of 35 Old 09-14-2013, 06:59 PM
SLADE
Not if you increase your tire size at the same time. Lower (numerically higher) gears can improve your fuel mileage when your running a tire that is too tall for your gear ratio. Larger tires make fewer revolution per mile so in turn it takes fewer revolution of the axle shaft to put the motor in it's RPM range for a given speed. The numerically higher gears also adds a mechanical advantage to help turn the taller and heavier tires.
Your average speed is also a factor on the fuel mileage for a given ratio. Most gear charts have are based on going around 70 MPH. If the average speed of your typical commute is only 45mph -60mph, you can run a numerically higher gear than the chart recommends and still maintain your fuel economy.
It has less to do with the number and more to do with matching the gear ratio, tire size, and speed to a given motors efficient RPM/power range.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
