gear ratio for Rubicon - JeepForum.com
post #1 of 35 Old 09-12-2013, 09:40 PM Thread Starter
jenniferjeep
2010 JK Wrangler
What is the gear ratio for a stock Rubicon? Will they be ok for a 35" tire?
jenniferjeep is offline
post #2 of 35 Old 09-12-2013, 10:20 PM
HappyTrails
HappyTrails's Avatar
4.10 is stock for a Rubicon.
No, you will not like it on 35's and 4.10's (if you know better).
If you have an automatic transmission, get 5.13's for 35's.
If you have a manual transmission, get 4.56 or better yet, 4.88's for 35's.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #3 of 35 Old 09-12-2013, 11:20 PM
suicideking
Rubicons are available with 4.10 and 3.73. Most are 4.10 which is fine for 35's. I have the 3.73 and it's acceptable, but not ideal.
suicideking is offline
post #4 of 35 Old 09-12-2013, 11:20 PM
AveCat
People do run 35s on 4.10s tho. It won't be as nice as 4.88s or 5.13s but it does work.
2012 Wrangler JK 3.6 W/ 6 Speed bought 2/15/13
2.5" Rock Krawler Lift - Bilstein 5100s - 315/70/17 Duratracs - AEV Control Arms
TruckLite - Rigid
AveCat is offline
post #5 of 35 Old 09-12-2013, 11:23 PM
HappyTrails
I had 4.10's on 32's...it was a dog, even for a Jeep!
JenniferJeep has the 3.8L engine...totally different animal than the 2012 (3.6L).
post #6 of 35 Old 09-12-2013, 11:24 PM
smcutter
Suicideking is running a different engine and drivetrain than the OP.
To JenniferJeep: You will not want to run 35's with 4.10 gears on your 2010 Rubicon.
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #7 of 35 Old 09-13-2013, 02:50 AM
TRAUMAhead
2010 JK Wrangler
5.38s all the way.
TRAUMAhead is offline
post #8 of 35 Old 09-13-2013, 06:42 AM
HighandLow
HighandLow's Avatar
2010 JK Wrangler
I run HEAVY 35's on mine with 4:10's. Superchip helps but yes, it is very piggy. Subscribed.
2010 Rubicon, Auto, Stone White, 3.5"Synergy Coils, DL and TR, MetalCloak TB's and CA's Fr/Rr, 37"Coopers 18" Ions , Adams 1310's, G2 5.13 gears, Synergy Sleeves and Gussets, ORF, PSC, JCR, PIAA,Rancho equipped...
HighandLow is offline
post #9 of 35 Old 09-13-2013, 08:24 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
I run 35s on my 2011 with 5.13 gears. Not bad but not best either - I have after gear remorse and wish I had gone with 5.38.
What I find amazing is the effect of tire weight. I have PitBulls on Raceline beadlocks for summer (offroad) and same size Hankoopk MTs on factory wheels for winter (on road) use. the pits are noticeably heavier than the Hankooks - VERY noticeable in off line response, freeway handling and road feedback. The unsprung weight of your suspension matters!
From 12 forward the Rubi has 3.73 or optional 4.10. BUT the pentastar is stronger at 1200 RPM and the transmission has a deeper 1st gear (both manual and automatic)
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
post #10 of 35 Old 09-13-2013, 10:43 AM
panthermark
2007 - current: 4.10's for all manuals.
2007 - 2011: 4.10's for automatics
2012 - current: 3.73's for automatics (4.10's are optional).
2010? Re-gear for 35's. 4.88's...maybe 5.13's..maybe deeper. Depends on if you have a stick or manual, if you have heavy wheels and armor, if you live near a lot of hills, ect...
Jeep - It's a Jeep thing...you wouldn't understand.
Triumph - Go your own way.
I see why I'm a loner....and I love it!
panthermark is offline
post #11 of 35 Old 09-13-2013, 05:21 PM Thread Starter
jenniferjeep
2010 JK Wrangler
What is an estimation of regearing cost?
post #12 of 35 Old 09-13-2013, 05:25 PM Thread Starter
jenniferjeep
2010 JK Wrangler
Looking at the chart above the 4:10 is not even good for a 32" tire! The stock tires are 255/75 R17 which is about a 32" tire. Is that correct?
post #13 of 35 Old 09-13-2013, 05:42 PM
HappyTrails
Yes, you are correct. 32's with 4.10's = sluggish. I had that setup in my Rubicon when it was stock. It was so bad that I was afraid to take the interstate because I could not accelerate quickly enough to merge with traffic.
A regear costs about $1000-2000 (parts and labor). Depends on where you live.
post #14 of 35 Old 09-13-2013, 06:55 PM
MikeHoncho88
2015 JK Wrangler
I'm running 35's with the 3.73's on my rubicon. It could be better, but it is not bad and definitely tolerable.
“Race fans, I had inferred from my one trip to the Brickyard 400, fell into one of two categories: tattooed, shirtless, sewer-mouthed drunks, and their husbands.” - Steve Ruchin
MikeHoncho88 is offline
post #15 of 35 Old 09-13-2013, 07:04 PM
smcutter
*sigh*
Again... MikeHoncho is running a different engine and drivetrain than the original poster.
smcutter is offline
