Gear ratio with 35's on JKU - JeepForum.com
post #1 of 14 Old 08-20-2013, 10:05 AM Thread Starter
csm41
What is the general consensus on the best gears in conjunction with 35's on the 2013 Unlimited? I just ordered a Rock Krawler 2.5" lift and some 35 x12.50's on Method Racing 17" wheels. I was thinking either 4.88 or 4.56's. I have 4.56 on my TJ with 35's, but that is with a 4.0 and an RH32 3 speed auto. Anyone with experience on the best all around set up?
csm41 is offline
post #2 of 14 Old 08-20-2013, 11:51 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Auto or manual? See FAQ for starters and then let us know which you choose. Suggested ratio is different for auto vs manual.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 14 Old 08-20-2013, 11:59 AM
brianjw
Your profile says Ohio. A lot of people are very happy with 4.10s in flat terrain on 2012+ with 35s. Since you're spending the money to regear, I would probably go for 4.56 gearing. Should be plenty low enough. Since you have a lot of higher speed limits up there I wouldn't want go too low and make the freeway miserable.
brianjw is offline
post #4 of 14 Old 08-20-2013, 12:03 PM
Astennis1
I have 4.10s 35s with a 6spd its fine, but if I were to pay money to upgrade from any less I would go to 4.56. Can't say much for the Auto.
I LOVE LAMP
13 JKUR
Astennis1 is offline
post #5 of 14 Old 08-20-2013, 12:03 PM
aznjeep
2014 WK
Scroll down to find the ratio charts for 2012+ http://www.jeepforum.com/forum/f96/h...35/index3.html
-Ken
'96 XJ Sport
'14 WK2 Overland EcoDiesel
'13 JKUR 10A (sold)
'10 JKUR (sold)
'99 TJ (sold)
aznjeep is offline
post #6 of 14 Old 08-20-2013, 01:52 PM Thread Starter
csm41
My JKU is an auto and a 3.6 Pentastar. I had looked at the FAQ gear chart previously, but the chart was for the 3.8 litre engine and the old tranny combo. Even if I was to go by that particular chart, my stock 32's are under geared with my stock 3.21 gears to begin with. I really don't trust the chart, which is why I was asking for real world experience. Although I live in NE Ohio, I travel a lot, often times in mountains. My TJ is for more heavy duty wheeling, but this new Unlimited is going to be my daily driver/camping/light trail rig. My plan is to regear and add Detroit Trutracs front and rear. When the Unlimited gets older, I plan on going to larger (37-40's) tires and axles and give the TJ to my kid.
csm41 is offline
post #7 of 14 Old 08-20-2013, 01:56 PM
HK_Runner
2014 JK Wrangler
4.56 would be perfect but for flatlanders, the stock Rubi 4.10 will work quite well. Here in Colorado, I curse the 4.10 only when going up the mountain passes and highways.
HK_Runner is offline
post #8 of 14 Old 08-20-2013, 01:57 PM Thread Starter
csm41
Thanks for the link. I just looked at the newer chart for my year Jeep, so I am back to my original thought of 4.88 or 4.56? I will just have to decide how high of RPM's I want to run on the freeway.
csm41 is offline
post #9 of 14 Old 08-20-2013, 02:00 PM
HK_Runner
2014 JK Wrangler
If not towing, go 4.56. I would not want to run around 3,000 RPM on the highway at 70 for any length of time.
post #10 of 14 Old 08-20-2013, 02:09 PM Thread Starter
csm41
This is good info. My Jeep buddies and I are planning a Colorado/Moab trip for early next year. 4.88 may be the best option for all around use. I still can't decide if I want to take the JKU or the TJ
csm41 is offline
post #11 of 14 Old 08-20-2013, 05:40 PM
SLADE
4.56's for the highway, flat land, and not towing.
4.88's for 2 lane, mountains, and towing.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #12 of 14 Old 08-20-2013, 06:25 PM
rha600
I have 35's and 4.10s here in Florida and it's fine, but if it were hilly I can see the 4.56s or 4.88s being a better choice.
rha600 is offline
post #13 of 14 Old 08-21-2013, 01:56 PM Thread Starter
csm41
I will probably opt for the 4.88 gears...
csm41 is offline
post #14 of 14 Old 08-21-2013, 03:15 PM
04WJfreedom
04WJfreedom's Avatar
Good choice I put in 4:88's last week and they are perfect for all the hills around here in New England!
2012 JK Unlimited Sahara
Rock Krawler 3.5" X-Factor MID arm lift
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
04WJfreedom is offline
