Gear help MPG? - JeepForum.com
post #1 of 6 Old 09-04-2012, 03:39 PM Thread Starter
caleb032
2010 JK Wrangler
Gear help MPG?
So I have a 2010 JK Unlimited 3.5" RC lift and 35" Federal Couragas and to be honest the gas mileage sucks! I am currently getting 11-12 MPG. What can I do to get some power and MPG back? From what I hear the answer is GEARS???
caleb032 is offline
post #2 of 6 Old 09-04-2012, 04:05 PM
paul84043
Did you adjust your computer to compensate for the larger tires? Stock tires to 35's will have you way off on the low side.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #3 of 6 Old 09-04-2012, 05:13 PM Thread Starter
caleb032
2010 JK Wrangler
yes I have
caleb032 is offline
post #4 of 6 Old 09-04-2012, 05:44 PM
DBA2GO
I'd recommend for an auto trans 5.13:1 gears (that is what I have) and for a manual trans 4.88:1 (from what I've read - no experience on this one).
One foot in the grave & one foot on the gas pedal!!
DBA2GO is offline
post #5 of 6 Old 09-04-2012, 07:38 PM
jstrubberg
2009 JK Wrangler
^^^^That.^^^
I got close to 3 mpg back on one by "right sizing" the gears.
Don't think you are ever going to get decent mileage out of a lifted rig, though. It's one of the things you give up when you go that route.
jstrubberg is offline
post #6 of 6 Old 09-05-2012, 09:22 AM Thread Starter
caleb032
2010 JK Wrangler
Yeah but my 2011 Hemi 4x4 get better mileage then my Jeep and its lifted with 34's! lol
caleb032 is offline
Which oil for AX15?? SYNTHETHIC Gear oil, Motor or Regular Gear OIL 915kingwrangler YJ Wrangler Technical Forum 17 04-05-2012 11:36 AM
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
D30 gear setup question (gear gurus needed) snowrydr01 TJ Wrangler Technical Forum 2 09-15-2010 09:00 AM
Dana 44 rubicon rear limited slip gear oil, synthetic or regular gear oil what weight rutacon05 TJ Wrangler Technical Forum 6 09-16-2009 08:53 AM
Spider Gear Missing a Tooth After Re-Gear Break-in Period beertinted TJ Wrangler Technical Forum 2 06-20-2007 01:34 PM
