#1 | |
Gear 3.21, 6 speed, 35s??
So how bad of an idea is this??? 6 speed, 3.21 gears, 35s..?
I guess this is why I am getting better gas mileage than what I have been reading... My 3.21 ratio... I have been getting like 20-22mpg...
#2 |
You could expect it to drop to around 11-12 at best and have no power at all.
PRESENT : 2008 Rubicon Unlimited | Rescue Green | OME HD Long Travel Kit w/ 40+ Coils| 37 x 12.5 BFG KM2s | Spidertrax Spacers | ProComp Extreme Alloy Wheels | Poison Spyder BFH Front Bumper | ARB Hi-Flow On Board Air | sPOD | Cobra CB |
#4 |
I think we are covering this is about 4-5 posts right now....
6.7 HEMI, ProRock 60's, Atlas 4 speed t-case, on board air, Teraflex long arm plus ACOS, 37 inch Maxxis Trepadors, 5.38 gears, AEV bumper, Custom AEV hood, Warn 9.5, Nemesis aluminum sliders and fenders, Or-Fab front cage, Poly Performance rear cage, Hutchinson Beadlocks, PJ rear bumper, HD Teraflex track bars, tantrum rock lights, woods shafts, corbeau LG-1 seats, Chaser Trailer........TIME TO PLAY!!! Colorado Jeep Club member #177 |
#5 |
Gold Member
Here is a real world answer.....
I own a 3.21 geared six speed X, with 3 inches of lift and 35s on it. This ride is my daily driver. I drive about 1200 miles per month. I've driven the jeep up and down our mountain passes (about 4500 feet, but fairly steep in some areas) many times, both solo, and fully loaded. It is true that 6th gear is rarely used. I typically shift around 3000 RPMs, but drive very comfortably at any speed I'd drive at under normal circumstances. When I bought this jeep, I did so assuming that I'd regear (I re-geared a 4 wheel drive expedition before, for better towing, so I'm fully aware of what re-gearing offers). A friend of mine suggested that I drive it for 6 months before I regeared. I'm 4 months into that, and I won't be re-gearing unless my driving habits or needs change dramatically. I have the money set aside for it, and the time involved isn't an issue-- but at this point I'll wait the two more months, and I can almost guarantee that the gear money will be going to other things. Re-gearing just isn't necessary for me. Like I said-- it's a daily driver, I travel up and down hills and mountains, and I do mild offroading (logging roads and trails-- but no rocks). It's completely capable of doing what I ask of it. Yes-- re-gearing offers advantages, torque and would allow quicker access to the power that my minivan engine offers. It just isn't necessary for me. Having the 6 speed allows me to control things very well. |
#6 |
I'm a fan of the 3.21 with the 6-speed and my stock 32s, but 35s would make me change my mind. I usually like to shift at 2700 tops and only if going uphill or passing. Usually it's 2000-2200.
If you shift like ge2, then you're probably all right to do like him and keep the 3.21. There's a lot of torque up in that rpm range, and that addresses the only negative to 35s: the increased torque requirement to get things moving.
LIQUIDS 2008 Wrangler Unlimited 4X4 - Jeep Green - 23S - Manual - Dual tops - Power group - Limited slip - 17" wheels - Side air bags - Sirius - Born 6 August 2007 1968 CJ5 - President Red - Dauntless - Ramsey PTO winch - 1980's full top - Unrestored and running (... but not stopping) Have Fun Out There. Jeep |
#7 |
Gold Member
5.13's and never looking back. Wit 4.10's and 35's my cruise control was useless, especially at 65 mph and higher. With 3.21's, it's going to be even worse than what I experienced. My fuel economy actually improved after regearing, not like I really care anyway, but it was a nice surprise. Oh, I have an automatic.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, BFG AT TA KO 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Bilstein 5100 series shocks, 5.13 gears, Alpine IDA-X001, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650 http://www.jeepforum.com/forum/f129/hothead-headliner-1237401/ http://web.me.com/stevenpeltierjr/Living_It_Up/Welcome.html |
#8 |
Gold Member
Prot... silly goose. You're last statement eliminates you
Didn't you read the title? You just read 'GEAR' and knew you needed to respond, right? I love your commitment ![]() Side note..... I just saw a license plate in our state this morning, that made me think of you. Does LA offer these? ![]() |
#9 |
Gold Member
Not sure, but I'll look into it.
I guess I'm enthusiastic about regearing because I can't believe how much of a difference it made without being so low that the engine is screaming. When I put it in 4LO, I can get out of my Jeep, go walk around get back in it without taking it out of gear LOL. My YJ's 4.0L was so much different than this 3.8L.
#10 | |
-Matt |
#11 | |
#12 | |
-Matt |
#13 |
Gold Member
I bought my gears and install kits for $700 and Cajun Offroad did the install for $300 per axle.
#14 | |
-Matt |
#15 |
Locked @ both ends
If you don't regear the front and you put it in 4wd, you tanke the chance of blowint the tcase because they will be turning at differnet speeds.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
