Gas tank overflow EVERY TIME when filling up?!? - Page 2 - JeepForum.com
post #16 of 41 Old 11-21-2012, 06:37 AM
Morb
Happens with my 2012 as well. Do you mean to tell me they haven't fixed this problem since 2008?
Morb is offline
post #17 of 41 Old 11-21-2012, 07:16 PM
Fizzle1979
2010 JK Wrangler
Mine does the same thing seems to have gotten worse in the past few months. When i took it to the dealer while under warranty with the issue, they claimed nothing was wrong.
| 2010 JK Unlimited Mountain | Rescue Green | Rugged Ridge Front Bumper | Rugged Ridge Winch Spacer | Rugged Ridge Rear Bumper | Rugged Ridge Tire Carrier | Warn Powerplant HD | Mopar Rock Sliders | Synergy Suspension Front & Rear Grab Handles | AEV 2.5" Lift | AEV Savegre Black Wheels | BFGR 35x12.50x17 KM2s | Rigid Dually LED | Boom Mat
Fizzle1979 is offline
post #18 of 41 Old 11-22-2012, 05:39 PM
Butterbuddha
2010 JK Wrangler
I thought everybody had gotten the dealer to fix this by now. I got a new tank, don't recall if they replaced the filler neck or not.
YOU CAN'T HANDLE THE TRUTH!
Butterbuddha is offline
post #19 of 41 Old 11-23-2012, 06:21 AM
92XJT
lol - fyi this problem isn't just on our JKs. My wifes WKII had the same issue(well it would spit out, but also cut the pump off within a few seconds constantly while filling), and since they didn't have info on it they replaced the tank (vehicle was only 2 weeks old). That didn't do it - after the second time the dealer replaced the filler hose and that did the trick.
Shoot even my 07 powerwagon had the tank replaced cause of the roll over valve was messed up and spit gas out every time when filling it.
92XJT is offline
post #20 of 41 Old 11-27-2012, 02:14 PM Thread Starter
Willey
Just got the news from the stealership - Got a bill for $97 for them just to look at it and they said the tank would be $900 Plus! ???? :/
Willey is offline
post #21 of 41 Old 11-27-2012, 02:24 PM
Taguilar
They're bending you over. Did you show them the bulletin that was mentioned previously? You may be able to report them for not honoring Chryslers extended warranty.
Taguilar is offline
post #22 of 41 Old 11-27-2012, 02:29 PM Thread Starter
Willey
They said mine was not covered under existing or extended warranty
Willey is offline
post #23 of 41 Old 11-27-2012, 06:56 PM
BLK2000TJ
Had the same issue with my 2008. Had the tank replaced when Chrysler extended the warranty. Now it's happening on my 2010.
2010 JKU Rubicon 3.5" AEV , AEV Pintlers 35" KM2's , AEV Bumpers, AEV Hood / Snorkel
2008 JKU (Daily Driver)
2000 TJ Auto 4.5 RE Superflex ,35" MTZ 's , Warn ,Viking, LoD, RockHard,AEV, JKS, ARB's, Vanco Big Brake Kit ,Currie etc. etc.etc.
BLK2000TJ is offline
post #24 of 41 Old 11-27-2012, 08:00 PM Thread Starter
Willey
Called Chrysler and they said they still won't cover it :/ Should I just order the filler tube or do I need to add a whole new / replacement tank too like the stealership said? What is the part number for the replacement filler tube that won't cause me headaches again?
Willey is offline
post #25 of 41 Old 11-28-2012, 10:51 AM
Taguilar
Wow! I really don't know what to yell you but to go to another Jeep dealership. Doesn't sound right.
Taguilar is offline
post #26 of 41 Old 11-28-2012, 06:18 PM
gfmcl
I would push, push, push.
My 2007 JKUR with 88K miles has this problem, and I got tired of dealing with it. My build date was 2/21/2007, 9 days before the TSB said it was covered. I talked to the dealer, they said call Chrysler Care. Chrysler said sorry. I called back to the dealer, pleaded my case, said it was an EPA and fire hazard and would they please talk to the area rep. They did, and it will be covered, $0 out of pocket. I'm thrilled.
Be persistent, and have the service manager talk to their rep. You may be surprised.
gfmcl is offline
post #27 of 41 Old 11-29-2012, 09:58 AM
GPV
It just happened to my wife and now she says it happens every time she can no longer just let it fill and shut itself off. It used to not be a problem, I thought we had somehow got lucky............................
Off to the stealership and see how they are going to treat the problem.
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #28 of 41 Old 12-01-2012, 09:26 PM
joe002
Maybe this can help? It's a copy of the letter I got:
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline
post #29 of 41 Old 12-28-2012, 11:48 AM
donny90yj
I'm at the dealership now getting my free oil, when I asked about them replacing mine they basically told me to pound sand due to the fact that it is a "service bulletin" and not a recall. Difference between them being a recall they'll fix, service bulletin is just a notice that the owner can fix, unless warranty covers it. I bought my 07 over a year ago with no warranty, but should they honor this "extended warranty" if I have nothing? You would think gas spilling at each fill up would rate a safety recall or something. Any help and/or documents appreciated.
donny90yj is offline
post #30 of 41 Old 12-28-2012, 03:02 PM
jcgribks
I don't know if this fix will work on a JK but it does work on the TJ. I had an 06 TJ and mine spit gas but then I traded it in on my 2012 JKU. I've had it spit once on my JKU but that was with the pump on full blast. Since then when I think I'm getting close to full, I just slow down the flow to about half speed and I haven't had a spit since.
Here's the thread on the TJ fix.
http://www.jeepforum.com/forum/f9/05...w-fix-1335243/
jcgribks is offline
gas
