Gas Mileage - 2013 JK - JeepForum.com
post #1 of 5 Old 02-24-2013, 09:10 AM Thread Starter
cpca3
I bought my first JK about 2 months ago. It's a 2013 Sahara Unlimited with a dealer installed 2" lift and 33" tires. I drive it mostly on the highway in cold Alberta, Canada. My problem is the gas mileage - at best it's getting about 350 km (218 miles) per tank. With a 22.5 gallon tank that works out to less than 10 miles per gallon. The on-board fuel economy display is showing a similar result - averaging about 23 l per 100KM (or about 10 miles per gallon). I took it into the dealer to get them to look it over and run a bunch of tests that did not reveal any obvious mechanical problems. (or so they say). The dealer said they could not do anything and poor milage is normal during the "break-in" period and that the lift and larger tires are also part of the problem. The Jeep has about 1,200 miles on it right now.
Everything I've read on this forum tells me I should be getting 15-20 mpg. At 70-75 Canadian dollars per tank, the jeep is quickly loosing it's appeal. My questions to the group:
a) is there anyone else out there with similar problems?
b) any ideas what could be wrong with it mechanically?
c) what should I do?
Thanks in advance!!
CP
cpca3 is offline
post #2 of 5 Old 02-24-2013, 09:23 AM
awinski
there are many people out there who experience poor fuel economy during break in. winter blends in fuel wont make it any better. if it were me, id wait till 6k ish. if it hasn't picked up by then, then take it in and complain.
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #3 of 5 Old 02-24-2013, 09:35 AM
222Doc
222Doc's Avatar
when you went 33 did you recalibrate?
a 33x10.5 is better for fuel than a 12.5 wide, more a tire is in the air steam.
I would think its more driver, if nothing is wrong with the Jeep
. Not that we are near the same. My 2d jkr with 35"s about 4" of lift, all the added steel fenders and bumpers. gets about 14-17 in town (that is what is on the build sheet read the small print.) I tend to get the 14 more, i am not a hyper'miller its a Jeep. Going out of town on long wheeling trips the Jeep has made 17-18.5 . For a Jeep thats outstanding
222Doc is online now
post #4 of 5 Old 02-24-2013, 09:53 AM
brianjw
2012 unlimited rubicon 4.10s six speed on 3.5" lift and 35s here. Typically 16mpg in town, 18mpg highway (60mph) or 15mpg at 70+mph. Lower in the winter with cold weather, crappy gas, standing water etc. Made a 1000 mile trip this winter with a solid 13-14mpg. It's a lifted jeep with big tires. Nothing I didn't expect.
You're getting winter blend gas which makes it worse, and I'm guessing you haven't recalibrated the speedometer so you aren't showing the actually mileage. Depending on your axle gearing it may be worse as well.
Recalibrate the speedo, put some miles on it and see what it does in the spring and summer.
brianjw is offline
post #5 of 5 Old 02-24-2013, 10:36 AM
Flood
I have a fully stock 2013 Jku Sahara 6 spd manual with 3000km/1800miles on the odo and am getting on average 14 litres per 100km or 16mpg, mostly city driving.
edit: I'm stuck in traffic alot, if i was to do mostly hwy driving I'd get closer to 19mpg.
2004 TJ Rubicon: Khaki, 2 inch BDS on 31's.
2013 JKU Sahara: 6spd, Billet Metallic (Family Hauler/Mall Crawler for now...)
1994 YJ: Blue, 4cyl, 3.5 lift, 31's - Sold
Flood is offline
jku , poor fuel mileage , poor gas mileage
