Garage hoist-a-top of a JKU - Page 3 - JeepForum.com
post #31 of 36 Old 09-12-2013, 01:41 PM
Deuskid
Question: it looks like the crank is at the end of the hoist unit. Could it be rotated 90* so that crank was to the side of the Jeep rather than the end [where the rear window would be in the way] since the platform is 4'x4' square anyway? It seems it'd be easier to operate from the side rather than the front/back of the JK.
Thanks,
john
Deuskid is offline
post #32 of 36 Old 09-12-2013, 01:42 PM
JIMBOX
Sure, all you gotta do is figure out a gear reduction box and multiple connections-
Originally Posted by TMJeep View Post
This looks like the best solution for me.
Can it be used with an electric hoist?
Take a look at the RACOR diagrams and see if you can use another hoist system-along withit
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #33 of 36 Old 09-12-2013, 01:46 PM
OutermostJeep
2009 JK Wrangler
The orientation of the unit depends on how you install it - which is dependent on the orientation of the ceiling joists in your garage. You can install supplemental braces perpendicular to your ceiling joists and then install it rotated so the gear box is on the side. However I find that it can be controlled from the side even when the box is mounted parallel to your jeep. They give you a long extension pole to use with your drill
OutermostJeep is offline
post #34 of 36 Old 09-12-2013, 07:20 PM
wilgeno
wilgeno's Avatar
Originally Posted by dmako View Post
Yeah low ceiling since I have a second floor above but garage is very long. I can lift enough to store and still park in front I figure.
Don't I only have to lift a few say inches to remove top?
I have a low flat roof garage an I was able to use my deer hanger as a lift to take the top off. It only needs to clear by an inch or so. Its trickier but doable. I ran to ratcheting tie down straps front to back on each side and then hooked them onto the deer hanger.
it worked and I didn't have to spend any money.
TeraFlexed '13 Commando Green JKU Black Hardtop roll'n on 35's!
Bug-Out!
I don't always go topless, but when I do I go Commando!
wilgeno is offline
post #35 of 36 Old 09-13-2013, 05:35 AM
TMJeep
Those that leave it hanging. Do you just use ratchet straps? Does it seem to distort the top when you go to put it back on?
98 Sport TJ 4.0L
Chile Pepper Red with Black Dual Tops
Trueflow Air Filter
31" BFG A/T
Cibies headlamps, plus 30 bulbs
other than that pretty much stock for now
TMJeep is offline
post #36 of 36 Old 09-13-2013, 06:00 AM
OutermostJeep
2009 JK Wrangler
I just use ratchet straps. Doesn't seem to have any effect on the the top.
