Garage hoist-a-top of a JKU - Page 2 - JeepForum.com
post #16 of 36 Old 05-30-2013, 11:25 AM
CoreyZ
Originally Posted by MEYJR View Post
Hey everyone, I am trying to decide how to do this as well, however my situation is a little different. I do not have a garage and I need to do it under a carport. My concern is the wind blowing the top around as it hangs. Has anyone made something under a carport that works?
The Racor lift looks interesting. Does anyone have any pics of their top hanging with it? Are you sliding the top onto the platform or removing it and using hooks?
Carport at your house, or your apartment?
If its at your house, dont see why it would be bad if you had straps holding it tight and not using just hooks like some homemade ones use.
If its at an apartment, forget about it unless you want to be fined for even touching that carport parking lol.
'12 JK COD:MW3 Edition
'10 WK, Black(sold)
Colorado Jeep Club member #217
CoreyZ is offline
post #17 of 36 Old 05-30-2013, 12:19 PM
Airborne Lee
Airborne Lee's Avatar
Oh yea, the harbor freight lift can be mounted on a pole/stut that hangs on a single heavy duty vertical pole. like a big 4x4. you could mount it so it swings out the the way. There are pictures of this configuration in the instruction booklet.
please buy this NEW IN BOX:
3 Previous Jeeps - 01 WJ Ltd, QD & UC - 01 WJ Ltd, QT II - 98 XJ Ltd
Airborne Lee is offline
post #18 of 36 Old 05-30-2013, 12:27 PM
JKommuter
2009 JK Wrangler
I lower the platform onto the top of my jeep,
run ratchet straps under the top, and tighten.
I put my freedom tops on the platform, then crank it up
and drive away. (Note: I zip tied swimming noodles to the bottom of the platform to protect the top)
Don't forget to remove all bolts, the hose and the plug. :-)
Not mine but I found one.
JKommuter is offline
post #19 of 36 Old 05-30-2013, 01:38 PM
MEYJR
It's my house so I can do anything once I figure out the best way.
MEYJR
2013 Wrangler Unlimited Sport, Deep Cherry Red, 2.5" Lift, American Racing ATX Thug Wheels, 35x12.5/17 Nitto Trail Grapplers
MEYJR is offline
post #20 of 36 Old 05-30-2013, 10:09 PM
JASJ
That's a great system and cheap option. "swimming noodles"?
Do you have specifics on needed parts?
That's the shiniest Jeep I've seen, realize its not yours.
JASJ is offline
post #21 of 36 Old 05-31-2013, 07:18 AM
JKommuter
2009 JK Wrangler
If I remember right everything comes with the lift. The crank has an
adapter so you can either use the speed handle or a cordless drill.
I might have gotten some longer lag bolts from home depot, but I don't remember.
Pool Noodles (like $1 at Walmart)
post #22 of 36 Old 06-06-2013, 01:32 PM
67alecto
2014 JK Wrangler
Originally Posted by REPPO View Post
Harken Hoist for me.
I have a harken as well - the non-powered version. The more I use it, the faster I can get the hardtop on and off. I had it off in 10 minutes last weekend.
Full disclosure: I also have the quick-release kit for the 6 bolts in the back so I only need a torx for the two over the front seats.
Between the hoist and my spiderweb shade, I'm rocking it.
Current: 2014 Flame Red Rubicon Unlimited.
Old: 2007 Steel Blue Sahara Unlimited
67alecto is offline
post #23 of 36 Old 06-16-2013, 04:06 PM
JKommuter
2009 JK Wrangler
I don't know if this will help the OP, or he already resolved this, here's pic of my top hanging on the Racor hoist.
The doors are hanging on the wall from a Rubbermaid Fasttrack rail I bought at Home Depot.
post #24 of 36 Old 09-12-2013, 06:22 AM
Deuskid
For those using a Racor hoist, what kind of 'brake' does the system have?
weight capacity is 250 # which seems more than adequate.
What, if any, modifications did you / would you make to make it more usable?
Thanks,
John
Deuskid is offline
post #25 of 36 Old 09-12-2013, 06:43 AM
Deuskid
Follow up question,
I assume everyone is leaving the top hanging from the Racor until re-installing. Maybe a bad assumption, so thought I'd ask. If you don't I assume you have some kind of cart or dolly?
Deuskid is offline
post #26 of 36 Old 09-12-2013, 06:51 AM
rainmn
2014 JK Wrangler
The Racor has a latch that puts a peg into the loop that you crank to raise / lower it. Even without that safety latch, I can't see it lowering itself.
To answer your second question, my hardtop has been hanging from my Racor since I installed it in March.
rainmn is offline
post #27 of 36 Old 09-12-2013, 08:11 AM
OutermostJeep
2009 JK Wrangler
I have the Racor as well and per the tip on this thread I put pool noodles on the bottom of mine. Use 2 ratchet straps on the top and lift away. I keep the freedom panels on the rack itself while the top is strapped to the bottom. It works amazingly well. You can raise or lower manually or with a drill (on low speed!!!!). The kit includes an adapter for your drill as well as a hand crank. There is a safety latch on the crank mechanism that locks it in place as mentioned. I left my top hanging all summer with no problems. 1 person operation to raise or lower. Takes about 30 minutes including bolting the top back on. Just make sure your garage has enough height. Best investment I've made in my Jeep so far!
OutermostJeep is offline
post #28 of 36 Old 09-12-2013, 11:11 AM
Deuskid
Excellent, looks like I've found my solution in racor!
Thanks,
John
Deuskid is offline
post #29 of 36 Old 09-12-2013, 01:26 PM
TMJeep
This looks like the best solution for me.
Can it be used with an electric hoist?
98 Sport TJ 4.0L
Chile Pepper Red with Black Dual Tops
Trueflow Air Filter
31" BFG A/T
Cibies headlamps, plus 30 bulbs
other than that pretty much stock for now
TMJeep is offline
post #30 of 36 Old 09-12-2013, 01:39 PM
OutermostJeep
2009 JK Wrangler
I suppose you could rig something but it is really designed to be used with a cordless drill - so you don't need an electric hoist. Basically the drill is the motor for the gear box on the racor unit.
