Garage hoist-a-top of a JKU - JeepForum.com
post #1 of 36 Old 05-28-2013, 02:08 PM Thread Starter
jkmax
2011 JK Wrangler
I'm very interested in buying one. What does everyone think!? Pretty sturdy?? Easy installation??
jkmax is offline
post #2 of 36 Old 05-28-2013, 02:22 PM
JKommuter
2009 JK Wrangler
I used a Racor lift I purchased from amazon. Easy to install, use your cordless drill to crank it up.
I can remove my top and doors from my JKU by myself in about 30 minutes give or take.
Hang the top from the lift using ratchet straps, put the freedom tops on the top of the platform. Check it out.
Racor lift on Amazon $140
Amazon reviews by other Jeepers who did the same
JKommuter is offline
post #3 of 36 Old 05-28-2013, 02:37 PM
dualtjs
2011 JK Wrangler
I did this for my TJ's hard top: 4 eye screws into the ceiling joists, 4 eye bolts into two 2X4's and 4 synch straps ($30 solution). I can remove the hard top and raise it, by myself (I use zip ties to ensure that it doesn't slip while I raise it up). I can raise it high enough to walk under it (I'm 6'1"). I'll use if for my JKU's hard top too.
dualtjs is offline
post #4 of 36 Old 05-28-2013, 03:44 PM
Lynhalla
Lynhalla's Avatar
I have the Lange power hoist-a-top. It is sturdy and easy to install. I have seen many home made versions on here and if you are handy and have the time, it may be worth doing to save money. If you havent already done so, do a search as there are threads that show pictures
___________________
2008 JK Unlimited X
RIPP stage 2 supercharger, R/K xfactor 5.5" long arm coilover susp., 40"x13.5" G/Y kevlars, 17x9.5 Raceline beadlocks, EVO gussets and sleeves, Yukon chromoly shafts, Artec trusses, T/W drive shafts, Eaton lockers, G2 5:13 gears, ORFAB front bumper with smittybuilt 12000 winch, Body Armor rear bumper, ORFAB roll cage, Mastercraft Baja seats, SPOD
Lynhalla is offline
post #5 of 36 Old 05-28-2013, 04:01 PM
JIMBOX
The RACOR Hoist is usually available for under $100 bucks and is a non-slip/multiuse/single person operated system-
This pic shows the RACOR after top install and using for other storage items and the MBRP JKU rack makes removal/reinstall quick/easy-
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #6 of 36 Old 05-29-2013, 02:14 PM
VICTIM_OF_PAIN
VICTIM_OF_PAIN's Avatar
I had the Lange hoist from my old TJ so I just used that. Works like a charm and no worries about it falling off.
Ex - 2001 Wrangler, 2" BB, 32" BGF AT's. JKS Quicker Disconnects, Oil Pan Skid, Steering Box Skid. Hard Top, Soft Top, Safari Top, Olympic Mountaineer Rack.
Current - 2008 Unlimited Wrangler Rubicon. Rock Krawler Stock Mod 2.5" lift, 35x12.50x15 Cooper STT's on Pro-Comp D-Windows, Husky Floor Liners, Mastercraft Grab Handles, Weathertech Side Window Deflectors, Hitch mounted D-Ring, Rancho Oil Pan Skid, Rugged Ridge E-Disco Skid, and a Skid Row Evap Canister Skid plate.
It is better to keep one's mouth shut and be thought a fool.... than to open it and remove all doubt.
VICTIM_OF_PAIN is offline
post #7 of 36 Old 05-29-2013, 02:21 PM
REPPO
Harken Hoist for me.
REPPO is offline
post #8 of 36 Old 05-29-2013, 04:11 PM
dmako
The Racor unit looks interesting.
Being 4 feet wide, is it too narrow for getting a top up high?
i.e. I'm looking for a solution for a low garage ceiling 8' 6"
dmako is offline
post #9 of 36 Old 05-29-2013, 04:32 PM
JIMBOX
The RACOR is 4'x4', so however it's mouted on the ceiling it'll accomodate any hardtop JK/JKU
if your ceiling is 8'6", you would have a very scary time removing/storing the hardtop-up in the air--doable, but freaky !
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #10 of 36 Old 05-29-2013, 04:50 PM
dmako
Yeah low ceiling since I have a second floor above but garage is very long. I can lift enough to store and still park in front I figure.
Don't I only have to lift a few say inches to remove top?
dmako is offline
post #11 of 36 Old 05-29-2013, 04:59 PM
JIMBOX
YUP, then backing in to remount--VERY CAREFULLY !!
Freedon tops OFF and rear hatch open--it'll work
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #12 of 36 Old 05-30-2013, 08:40 AM
MEYJR
Hey everyone, I am trying to decide how to do this as well, however my situation is a little different. I do not have a garage and I need to do it under a carport. My concern is the wind blowing the top around as it hangs. Has anyone made something under a carport that works?
The Racor lift looks interesting. Does anyone have any pics of their top hanging with it? Are you sliding the top onto the platform or removing it and using hooks?
MEYJR
2013 Wrangler Unlimited Sport, Deep Cherry Red, 2.5" Lift, American Racing ATX Thug Wheels, 35x12.5/17 Nitto Trail Grapplers
MEYJR is offline
post #13 of 36 Old 05-30-2013, 09:07 AM
Airborne Lee
Airborne Lee's Avatar
I just posted mine on the general forum.
http://www.jeepforum.com/forum/f176/...build-1529699/
please buy this NEW IN BOX:
3 Previous Jeeps - 01 WJ Ltd, QD & UC - 01 WJ Ltd, QT II - 98 XJ Ltd
Airborne Lee is offline
post #14 of 36 Old 05-30-2013, 09:17 AM
JIMBOX
Sorry, no pics with mine and I have the MBRP rack so my removal using "J" hooks on cable-below the RACOR platform was easy, but
I've gotta 10' ceiling in my garage, I'd be hesitant trying this in a carport !
These hardtops aren't actual "Fiberglass" so they are really prone to cracks/fractures with the slightest bump/jar/rap--
Gotta be careful-
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #15 of 36 Old 05-30-2013, 09:23 AM
dualtjs
2011 JK Wrangler
I would wager that bungee cords (or perhaps synch straps) from the 4 corners of the bottom of the top to the posts of the car port would work nicely. I would also leave the back door open so wind can flow through would be a big help too.
dualtjs is offline
