Garage door opener, soft top, 8000 miles.... - JeepForum.com
post #1 of 21 Old 04-24-2007, 01:12 PM Thread Starter
jeepers3
0123456789
jeepers3 is offline
post #2 of 21 Old 04-24-2007, 01:20 PM
BirdsFanVa
BirdsFanVa's Avatar
Topless is great stuff. You can always lock it in your console or your glovebox if you are worried about security. I think it looks silly on the visor anyway and found that it rattles. I just leave mine in my Thule side storage as seen here, A great add on for $14.00. When your topless it helps keep little things from blowing around. It works and it is kind of out of sight out of mind. Like I tell the wife when she's in the Jeep, If it's important to her, take it with her. Just my opinion, but I really never even lock it with the soft top up or down.
[IMG][/IMG]
07 Black Sahara Unlimited 2.5" Skyjacker suspension lift, RE quick discos, 3/4" front spacers, 16x8 soft 8's, BFG 33x12.50's MT's, Shrockworks rock rails. Bulldog rock crawler winch bumper, Warn M8000 and lot's of armor! (Mine)
08 Redrock X Unlimited (Hers)
____________________________________________
Driving a Jeep to work makes it feel like you're going camping!
BirdsFanVa is offline
post #3 of 21 Old 04-24-2007, 01:29 PM
FLSeaMonkey
I agree with Birds, I have the same Thule thingy and it comes in quite handy, garage opener, shades, tazer to keep all the beautiful women from attacking me in my Jeep etc....
'07 Wrangler Unlimited Sahara Rescue Green
'94 Land Rover Defender 90
'64 Porsche 356C
FLSeaMonkey is offline
post #4 of 21 Old 04-24-2007, 02:07 PM Thread Starter
jeepers3
0123456789
jeepers3 is offline
post #5 of 21 Old 04-24-2007, 02:18 PM
Kyoseki
Inconceivable!
Kyoseki's Avatar
I use a keychain garage door opener, no worries about leaving anything in the Jeep then.
You can get them for most popular makes and models of GDO.
Due to lack of interest, tomorrow has been canceled
Kyoseki is offline
post #6 of 21 Old 04-24-2007, 02:23 PM
alanlight
Originally Posted by jeepers3
Good idea, but such a device is incompatible with side airbags (:
I see the side airbags tag on the seat in that photo too - I wonder if you thought about such a thing, or if you just don't care (and if so, then why get the side airbags), or if you think the side airbags will deploy fine even with such an item attached, or what.
I might be wrong here, but aren't the side airbags only on the *outside* sides of the seats? After all, they are designed to protect from a side-impact.
alanlight is offline
post #7 of 21 Old 04-24-2007, 04:48 PM Thread Starter
jeepers3
That's true....but I couldn't tell from the photo that it was the inside part. I figured it was a photo of the driver's side, which would make it the outside. Doing a double take - yeah, I see that is the inside of the passenger's side (:
jeepers3 is offline
post #8 of 21 Old 04-24-2007, 05:05 PM
Matthew Davis
So, my question to you guys is - what strategy are you guys using for garage door openers?
Hi Jeepers,
I took the visor clip off the remote and found that it wedges perfectly in the little 'shelf' in the front of the center console (on the right front side inside). It stays put and out of the way.
Matt
Matthew Davis is offline
post #9 of 21 Old 04-24-2007, 05:51 PM
donkie
Flash to open is another option, but adding the keypad outside of your garage that opens the door also solves lockout problems...you could also replace your rear view mirror with an aftermarket temp/homelink mirror and open it from your Jeep that way. Tuffy security console is another place to stash it.
http://www.autodimmingmirrors.com/newstore/ About $150 or so on fleabay
Recovering Jeepaholic
2007 Wrangler Sahara - SOLD
Geaux Tigers!!!
donkie is offline
post #10 of 21 Old 04-24-2007, 06:23 PM
CJATE
I 3m mine up under the dash, out of sight.
83 CJ-8 scrambler
SOA
Locked and Twin-sticked
35's, fenders cut
4.56
bad paint
leaks just about everything
CJATE is offline
post #11 of 21 Old 04-24-2007, 06:29 PM
BirdsFanVa
BirdsFanVa's Avatar
Yep. Side airbags deploy from the outside of the seat to the side of the vehicle. This does not hinder the deployment and the Thule is attached to the headrest and the bottom of the bucket.
post #12 of 21 Old 04-24-2007, 06:32 PM
BirdsFanVa
BirdsFanVa's Avatar
No it's the inside. I would put another on if I could reach it behind me. I really love this cheap add on. The second compartment holds my cell at a perfect spot to hear it ring while heading down the road at 60+ with the top dropped.
post #13 of 21 Old 04-24-2007, 06:43 PM
MD23
Initially I had mine clipped to the seat adjustment bar under the driver's seat. That turned out to be more hassle than I was willing to deal with. My solution was to clip it upside down to the visor, and use a Sharpie to color the stainless clip to match the visor color. It does not interfere with visor operation.
If some pillar of society steals it and follows me home, I guess I will fall back on Smith and Wesson or, in my absence, the 85 pound Akita home security system.
Side bar ...I do not lock my doors even when the soft top is up either. It's cheaper and less inconvenient that way.
MD23 is offline
post #14 of 21 Old 04-24-2007, 06:51 PM
Gr8gugly
took advive from someone else and tucked it in the roll bar padding just above the drivers head. It isn't conspicuous but you know where it is and can operate it while it is still inside. I had it in the console but didn't like opening it everytime I wanted to get in the garage.
Gr8gugly is offline
post #15 of 21 Old 04-24-2007, 06:52 PM
joshg302
My dad is redoing his lawn and has a big mudpit and a big hump of dirt where grass should be. Forget the garage, he enjoys parking it in the mud with one tire up on the hump!!
Josh
joshg302 is offline
garage door opener Jstin120 TJ Wrangler Technical Forum 60 06-28-2014 12:10 PM
Garage door opener in TJ erickpl TJ Wrangler Technical Forum 49 06-04-2013 01:36 PM
garage door opener Brent_f70 JK Wrangler Technical Forum 9 05-01-2008 08:05 PM
Garage Door Opener - Mod u4ea TJ Wrangler Technical Forum 13 07-24-2003 09:29 AM
Garage door opener solution? Tyler Dirden TJ Wrangler Technical Forum 12 09-09-2002 11:01 AM
