Fuel Pump Wiring Diagram - JeepForum.com
post #1 of 4 Old 04-14-2014, 02:48 PM Thread Starter
Maertz
2009 JK Wrangler
I am wondering if anyone can let me know what each wire does on the fuel pump. If i recall correctly there are 4 of them. I found a wire diagram but suck with electronics.
http://www.trailduty.com/temp/fuelpump.pdf
It seems like itd be the 4 wires in the upper right corner, but for some reason i swear one was pure black. I will have to double check when I get home. If that diagram is correct i would use c1 as my ground, but would i use c5 or c1 on the new fuel pumps power wire. My new fuel pump has a ground and positive only.
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #2 of 4 Old 04-14-2014, 02:57 PM
73azbronco
DB/OR (Dark Blue Orange?) as power, and BK (Black) as ground. Verify with volt/ohmmeter.
The DB and DB/DG are sensor wires for the fuel control. Not sure how in your application you would handle those. Note the resistor inside the fuel pump.
73azbronco is offline
post #3 of 4 Old 04-14-2014, 03:03 PM Thread Starter
Maertz
2009 JK Wrangler
At the moment i think I would disregard those sensor wires. As for the resistor i dont think I will need? I have a standard inline fuel pump.
Maertz is offline
post #4 of 4 Old 04-14-2014, 03:46 PM
ronjenx
ronjenx's Avatar
The thing after the fuel pump motor in the diagram isn't a resistor. It's the symbol for a circuit breaker or PTC protection device.
Probably the PTC in this application.
ronjenx is offline
