Fuel Filter Change? - JeepForum.com
post #1 of 16 Old 09-18-2009, 11:50 AM Thread Starter
devilsfiddle
Fuel Filter Change?
How often should you change the fuel filter? And how much should it cost?
JK 08 X
devilsfiddle is offline
post #2 of 16 Old 09-18-2009, 01:08 PM
08BlueSahara
Fuel Filter??
Hey There,
I thought this would be in the manual, but this is all I could find in the manual about the fuel filter:
Spoke to the parts dept of my dealer to get the MOPAR part # and was told that there is no replaceable filter for the Jeep. It's part of the fuel module (or fuel pump unit) and is not serviceable.
Anyone else with experience or knowledge of the fuel filter??
08BlueSahara is offline
post #3 of 16 Old 09-18-2009, 01:24 PM
DeepSky
Well that sounds like an expensive alternative to what is normally an inexpensive replacement....
DeepSky is offline
post #4 of 16 Old 09-18-2009, 02:13 PM
sethco
I dont know how much it should cost but I had a dodge dakota which the fuel filter was in the tank and it cost $250-$300 for a new filter (filter was in the fuel pump...and had to replace it all) that was just for parts, I had to pull the bed to remove the tank to get it all changed, it was fun...... (local dealership told me it was going to be about $1,300 to have it done there)
My chevy Z71 cost about $5 and took about 5 min....
Going to church doesn't make you a Christian any more than standing in your garage makes you a car.
sethco is offline
post #5 of 16 Old 09-18-2009, 02:22 PM
gravely_todd
My 2002 Intrepid doesn't have a replaceable fuel filter either....just the sock attached to the fuel pump too...I have 183K miles on it with no problems.....so far anyway.......must be a Chrysler thing.
Todd
2008 Sahara 2-door
Red Rock / Khaki
6-speed, Dual Tops, MyGig, Power and Tow Package
and YES I like the silver bumper inserts !!!
gravely_todd is offline
post #6 of 16 Old 09-19-2009, 06:42 AM
irishgearhead
the fuel filter is part of the fuel pump assembly and is replaced with the pump. when the pump fails!
If it will float, fly or **** its cheaper to rent!!
irishgearhead is offline
post #7 of 16 Old 09-19-2009, 08:56 AM Thread Starter
devilsfiddle
reply
thank you. thats different that my last vehicle which was a mustang
JK 08 X
post #8 of 16 Old 09-19-2009, 10:06 AM
virtual_mage
2009 JK Wrangler
You can had a in line fuel filter,lots of people just relocate it under the hood just before the fuel rail,you can always with the proper fitting use an after market fuel pump to,as long is use the proper flow rate .
virtual_mage is offline
post #9 of 16 Old 09-19-2009, 10:40 AM
irishgearhead
The way i see it is jeep (chrysler) spent millions on R&D. if they put the fuel filter where is was working the best in the pump assembly. So why screw with their R&D and put one near the rail. leave it alone and when its time to replace the pump it comes as an assembly. DO NOT ADD AN EXTERNAL FILTER!
post #10 of 16 Old 09-19-2009, 11:23 AM Thread Starter
devilsfiddle
Thank you for your advice.
JK 08 X
post #11 of 16 Old 09-19-2009, 11:48 AM
VIJeeper
An external filter would do nothing as long as the fuel was passing through the one inside the pump. The internal pump filter would still eventually clog and fail while the inline filter would likely remain clean.
An inline filter would only make sense if it pre-filters the fuel going into the pump preventing its eventual demise.
My Jeep: 2007 Wrangler Unlimited X. Rescue Green, 6 speed.
VIJeeper is offline
post #12 of 16 Old 09-19-2009, 11:54 AM
Steve98
Todd
I'd say its more like a stupid thing But hey, the bankrupt engineers must know better. My ZJ had an external filter under the jeep, near the tank.
2006 LJ Rubicon
Steve98 is offline
post #13 of 16 Old 09-19-2009, 12:25 PM
irishgearhead
yeah but your zj was fuel filter/pressure regulator!
post #14 of 16 Old 09-19-2009, 04:13 PM
tkob1060
2016 WK
there are already 2 filters actually in the tank, one built into the fuel pump module and one on the bottom of it.
even with just one in the tank wth you think adding an external would do?
now go look for the a/c filter
tkob1060 is offline
post #15 of 16 Old 09-19-2009, 05:58 PM
virtual_mage
2009 JK Wrangler
never realized that the filter was on the pump.....still its somehow strange i find, guess still have lots to learn about the jeep world.
fuel filter change ton12loc YJ Wrangler Technical Forum 2 12-15-2008 08:58 AM
Fuel Filter Change getpower YJ Wrangler Technical Forum 4 04-16-2008 08:37 AM
Fuel Filter Change on a 98 TJ mknherhappy TJ Wrangler Technical Forum 12 10-09-2007 10:45 AM
How do you change the fuel filter? rlacey YJ Wrangler Technical Forum 12 05-20-2005 05:45 PM
Fuel Filter Change Patrick Bateman YJ Wrangler Technical Forum 6 09-02-2003 09:17 AM
