-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Front Upper Shock Bolt (http://www.jeepforum.com/forum/f96/front-upper-shock-bolt-1635657/)
janders82 09-29-2013 08:23 PM
throwing some new shocks on and wondering how tight to tighten the the upper shock bolt for the fronts (i don't currently have a torque wrench).
i cranked them down to where the bushings is pretty much the same diameter as the washers. tight enough?
Maertz 09-29-2013 08:27 PM
doesnt have to be crazy, id guess about 20 ft/lbs. mine are not squished down to bad at all
janders82 09-29-2013 08:32 PM
thanks. i'm pretty sure that 20 ft/lbs is the spec. its just that i don't have a torque wrench at the moment
1222 09-30-2013 04:44 AM
For the upper front shocks all you need to do is tighten them up to remove all slack and make them snug, then give the nut/nuts a turn or two more. Over compressing the rubber bushings to the point of deforming them is a quick way to destroying them in very short order.
Never heard of using a torque wrench on the upper shock stems, a wrench is all thatís needed. Besides, itís imposable to get one up there anyways.
:cheers2:
janders82 09-30-2013 10:52 AM
Originally Posted by 1222
For the upper front shocks all you need to do is tighten them up to remove all slack and make them snug, then give the nut/nuts a turn or two more. Over compressing the rubber bushings to the point of deforming them is a quick way to destroying them in very short order. Never heard of using a torque wrench on the upper shock stems, a wrench is all that’s needed. Besides, it’s imposable to get one up there anyways. :cheers2:
THANKS for this. was hoping you would chime in...i was thinking the same thing about the torque wrench. i can't even get a socket up there, how in the heck am i going to fit the torque wrench?
thanks for the input. your explanation is pretty much exactly what i did for the top nut.
1222 09-30-2013 04:10 PM
Your welcome and yup itís a tight fit especially on the pass side.
:cheers2:
The time now is 10:35 PM.
