Which Front Track Bar? 2.5" Spring Lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Which Front Track Bar? 2.5" Spring Lift
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOfficial Chassis Saver Rust Preventive Truck & Auto UnFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 09-27-2013, 02:23 PM   #1
jeremylj1972
I am anal and want to install an adjustable track bar on the front of my 2013 JK. I have an AEV 2.5" spring lift with geometry correction brackets.
What brand front track bar seems to be the best?
jeremylj1972 is offline   Reply With Quote
Unread 09-27-2013, 02:32 PM   #2
ROCKR8R
http://www.polyperformance.com/shop/...l#.UkXrHc_n-ig
-Dan
ROCKR8R is offline   Reply With Quote
Unread 09-27-2013, 03:58 PM   #3
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I went with the JKS and it works fine for me...front and rear.
http://jksmfg.com/i-8938526-wrangler...-trackbar.html
http://jksmfg.com/i-8938535-wrangler...-trackbar.html
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 09-27-2013, 04:34 PM   #4
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
Rock Krawler on my AEV, works great!
08 JK Sahara | AEV | Rock Krawler | BFGoodrich | Yukon | ARB | Solid | Bushwacker | Yakima | Rigid Industries
MoonyJohn is offline   Reply With Quote
Unread 09-27-2013, 04:43 PM   #5
JTPhoto
TeraFlex Monster Trackbar.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited. Auto, Tow pkg, Dual Tops, MyGig, Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 35x12.50x17 Pitbull Rockers on Blackrock Viper Alloys, Flex-o-lite trans cooler, Mr Grille billet grille inserts, AEV Prem Bumper ETC.. AND a Locked and Lifted Honda Foreman for when the trails get real tight
JTPhoto is offline   Reply With Quote
Unread 09-27-2013, 06:10 PM   #6
Vin
+1
I installed a Teraflex 2.5 lift, so it made sense to me.
Vin is offline   Reply With Quote
Unread 09-27-2013, 06:14 PM   #7
halfpint153
2011 JK Wrangler
I did the teraflex TB, just change out the factory TB bolts while your in there. 9/16 x 3" fine thread fit a lot better than the mectric stock bolts.
halfpint153 is offline   Reply With Quote
Unread 09-27-2013, 06:24 PM   #8
awinski
i like turtles
awinski's Avatar
Ive seen two tf track bars break in person, another online, ORE's king of the hammers rig "evo 1" still runs the stocker. Bracket make a choice but personally id go synergy or jks
one more horse power than the average pentastar http://www.jeepforum.com/forum/f22/p...build-2157673/ i love comments!
Rock krawler * Falken *Genright * Artec Arb * Poison Spyder * Synergy * Fox * Ruff Stuff * Metal Cloak the list goes on!
awinski is offline   Reply With Quote
Unread 09-27-2013, 07:53 PM   #9
JTPhoto
That was the old design which were taken off the market. The threaded piece on the new model is bigger in diameter then the factory Trackbar. You gotta be in some serious rocks to break that.
^^Jeff^^
Unread 09-28-2013, 07:15 AM   #10
Remmy18
Originally Posted by ROCKR8R
x2
Remmy18 is offline   Reply With Quote
Unread 09-28-2013, 01:35 PM   #11
RockyClymer
RedRock4Wheeler
And....the 3 in 9/16 bolt needs to be shouldered to keep from tearing the bushing apart!
NRA Life member
Unread 09-28-2013, 03:45 PM   #12
Psycho-X-Jeep
Free hugs <<< just ask!
Psycho-X-Jeep's Avatar
2009 JK Wrangler
I have the Rock Krawler adjustable TB. The thing is beefy!
I do have a follow up question to the original one. How did everyone torque the jam nuts properly? They were the only things I couldn't torque to spec. I did put the bar in a vice and wrench the you-know-what out of them. But I have no clue if I hit the 200-220 ft-lb mark. Should I be worried?
Psycho-X-Jeep is offline   Reply With Quote
Unread 09-30-2013, 09:09 AM   #13
tslewisz
2010 JK Wrangler
I basically did the same as you, along with Loctite blue in the bar and the jam nuts. Mine haven't moved.
I have RK's on both ends from the Pro (7075 aluminum) line.
tslewisz is offline   Reply With Quote
Unread 09-30-2013, 09:13 AM   #14
Maertz
Hating Jk's Since 07'
Maertz's Avatar
2009 JK Wrangler
is fabbing one an option? its what i did and it cost me about 75 dollars....
Maertz is offline   Reply With Quote
Unread 09-30-2013, 11:12 AM   #15
jeremylj1972
Thank you all for your replies!!! I decided on the Rock Krawler bar due to its low cost and good reviews. Supposed to take a couple weeks to get so I will update when I get it installed.
Last edited by jeremylj1972; 09-30-2013 at 11:29 AM.. Reason: Adding new information.
