Front Speaker Replacement - JeepForum.com
post #1 of 12 Old 06-03-2007, 11:13 AM Thread Starter
KNOCKOUT
Has anyone attempted to replace the front 6 1/2" midbass speakers located inside the dash? The stock speaker covers seem to be part of the side panels of the dash. Anyone have any advice or experience here and want to share??? Thanks so much!!! Need to get some sound improvement ASAP!!!
2007 JK, Flame Red, Work In Progress!
KNOCKOUT is offline
post #2 of 12 Old 06-03-2007, 01:33 PM
BIGKernel44
i could be wrong but when i was searching for replacements for mine they list them as 6 3/4 speakers
BIGKernel44 is offline
post #3 of 12 Old 06-03-2007, 06:34 PM Thread Starter
KNOCKOUT
I am wondering what the easiest way to get to the speakers is... seems to be part of the dash and didn't know if it was going to really be that much of a pain to get off, and if someone has figured out the easiest way to get to them... Thanks! And, as far as the speaker size, we have 6 1/2s and they fit. I am sure a 6 3/4 would fit also... alright, thanks again for any help or suggestions
KNOCKOUT is offline
post #4 of 12 Old 06-03-2007, 06:47 PM
Prot
Prot's Avatar
2014 JK Wrangler
I had the factory premium system in mine and I yanked it out. I replaced the dash speakers with 6020CS 6 1/2" Infintiy components. These require an amplifier to sound their best. See my thread entitled My JK Finally
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #5 of 12 Old 06-03-2007, 07:44 PM
ksjeep226
Check this out...
http://www.jeepforum.com/forum/f20/new-stereo-system-installed-392338/
2007 Wrangler
2005 Liberty
2002 VFR
ksjeep226 is offline
post #6 of 12 Old 06-04-2007, 11:38 AM
BIGKernel44
not to jack your thread, but 6 1/2's fit the dash and the roll bars then correct? is there any info on a wiring harness and dash kit available yet? I was told Metra makes the dash installation kit but I can't find any harnesses out there yet and I would really like to avoid splicing the wires. I just traded my 2004 wrangler in for this 2007 and I got to put all the stock stuff back in because I used harnesses for everything.
post #7 of 12 Old 06-04-2007, 07:49 PM Thread Starter
KNOCKOUT
Yes, 6 1/2s in dash and roll bars. Did you check with Crutchfield on the wiring harness? They are usually a pretty good start if you haven't done that already. They were able to tell us what would work in there. The only thing was that they were saying that the Polk speakers we got for the speaker bar would be too big, but we got it to work. One note- the holes are bigger than the speakers, so you'll have to use speaker adapter brackets, which came with ours through Crutchfield since they knew what we were using them for. Anyway, check their site, or call them and see if they can help.
KNOCKOUT is offline
post #8 of 12 Old 06-05-2007, 04:51 AM
Prot
Prot's Avatar
2014 JK Wrangler
If you have the factory Infinity system, the head unit harness is around $124 and if you don't, it's $90, so it's not going to be a freebie like with most crutchfield purchases. Crutchfield doesn't even carry it yet, but they do give you the dash kit for free when you buy a headunit from them. Here is the link for the head unit harness:
http://www.autotoys.com/x/cust/produ...productid=9979
Prot is offline
post #9 of 12 Old 06-11-2007, 09:31 AM
road-king
I ordered 6 1/2" Polk for the roll bar, and 6 1/2" Polk components for the dash from Crutchfield. They included the correct wiring adapter for the speakers and the speaker brackets. The bracket screw holes didn't line up perfectly, but that wasn't a problem. I also clipped the connectors off the front wiring adapter because I was using components. I also had to trim the stock tweeter housings to get the aftermarket ones to fit.
More importantly, what I thought was going to be an hour long job took me 6!!! I would like to meet the designer of the dash and slap him so hard his grandchildren will feel it.
It boggles my mind that they didn't have seperate covers like the TJ. Hello! Jeeps get wet and speaker replacement is a fact of life... Luckily the Polk's I got are marine rated so hopefully they will survive a little rain water.
"He loves the mud! His mother was a mudder! His father was a mudder!"
Current: 2007 Wrangler X Unlimited / 4-dr / 4-wd
Previous: 2004 Wrangler Sport
Previous: 1996 Wrangler Sport
road-king is offline
post #10 of 12 Old 06-11-2007, 06:46 PM
Squint
Squint's Avatar
So is theft. What's worse: the labor involved or the cost, but I feel your pain.
07 JK 2 Door X; Bright Silver; Auto; package 24C; tow hooks; fog lights; Incubus Alloy Type 511 17x9 (4.53" backspacing); 305/70R17 Summit Mud Dawg M/T tires; Daystar 1 3/4" BB w/ Skyjacker Hydro 7000 shocks; Hella 500 driving lights; Hidden Hitch; Mastercraft 3" grab handles; Alpine CDA-9857; MTX 6.5" fr speakers; Cobra 18 WX ST II; power adders: JeepForum.com sticker :)
Squint is offline
post #11 of 12 Old 06-15-2007, 06:48 PM
xx94cherokeexx
is there an amp to power the sub that comes with the premium sound? is there an amp hidden some where?
xx94cherokeexx is offline
post #12 of 12 Old 06-16-2007, 07:27 AM
Prot
Prot's Avatar
2014 JK Wrangler
The amplifier that comes with the factory premium infinity system powers all four speakers and the subwoofer. It is located under the steering column behind the lower access panel.
Prot is offline
YJ Dash speaker replacement ROADDOG516 YJ Wrangler Technical Forum 31 10-03-2013 02:30 AM
Replacement Speaker Help Needed Bret Wrangler General Discussion 1 02-09-2010 09:18 AM
Soundbar speaker replacement LM3 TJ Wrangler Technical Forum 10 09-23-2009 10:44 PM
03 front speaker dave's jeep TJ Wrangler Technical Forum 3 08-01-2009 09:16 PM
Front speaker box....... rondawg JK Wrangler Technical Forum 5 03-09-2008 03:07 PM
