Front speaker box....... - JeepForum.com
post #1 of 6 Old 06-16-2007, 06:25 PM Thread Starter
rondawg
I replaced the stock speakers with infinity components, the new speakers sounded tinny. Has anyone else had this problem? I'm thinking about stuffing some foam in the boxes behind the speaker to see if this will help. Has anyone tried that also? And have decided to try a different speaker to see if that was the problem. I bought Polk Mommo which are supposed to be incredible! Time will tell.
rondawg is offline
post #2 of 6 Old 06-16-2007, 09:17 PM
Prot
Prot's Avatar
2014 JK Wrangler
Look at the power ratings of the speakers you bought. If the power rating is high, then that means they are meant to be driven by an amplifier. Speakers that require an amplifier that are driven off of the head unit alone will sound shallow even if they are expensive.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #3 of 6 Old 06-16-2007, 11:32 PM
Laxstar46
Polk mommos are excellent. I love mine. I run 4x6's in my front and 6.5's in my soundbar of my TJ. great speakers. when you say components do you mean they have a seperate tweeter and woofer assmebly or just a regualr coax speaker. If you bought components those are strictly meant to be with an amplifier. most coax speakers can run on a deck and be just fine even if they have apower rating higher than that. almost all speakers are rated at an RMS of about 40. the higher up models are higher but most are right around 40. and no h/u alone will pump out 40 rms some of the best put out 20. that's about it. but I wouldn't worry about that. If they are soudning tinny then your tweeter is overpowering your woofer. try reducing treble on the h/u to possibly get rid of that tinniness.
Laxstar46 is offline
post #4 of 6 Old 03-08-2008, 09:25 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
I installed a pair of speaker baffles with Infiniti speakers up front for my TJ. It's basically a molded foam enclosure that mounts back side of speaker, designed to push sound towards front. Sounds definately improved, richer. Got mine from crutchfield.com
2009 JK Rubicon
Shrockworks Mid-width Bumper, Warn 9.5Ti Winch; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skid Front & Rear, 11,000# Pull-Pal. Uniden 520XL CB; Bilstein Shocks, 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - 8/2007
Rubicon - 9/2008
Thunderstrike is offline
post #5 of 6 Old 03-09-2008, 02:53 PM
liquids
liquids's Avatar
I installed Boston components in my Dakota a few years ago. Ran into the same issue, but the supplied crossovers had three separate jumper switches for how much power you wanted going to the tweeters: 0, -2db, and -4db. At the -2db setting they were strong. I kept my high-end eq settings low on the head unit.
Btw, I don't believe the hype about the components "wanting" to be driven by an amp.
LIQUIDS
2008 Wrangler Unlimited 4X4 - Jeep Green - 23S - Manual - Dual tops - Power group - Limited slip - 17" wheels - Side air bags - Sirius - Born 6 August 2007
1968 CJ5 - President Red - Dauntless - Ramsey PTO winch - 1980's full top - Unrestored and running (... but not stopping)
Have Fun Out There.
Jeep
liquids is offline
post #6 of 6 Old 03-09-2008, 03:07 PM
Warlord2
if you installed components, did you replace the tweeters also? If you did then you have to buy aftermarket crossover for it because the stock one will sound like crap. I tried using the stock wiring and just change tweeters and it sounded "tinny" to me also so I had to use the ones that my polk speakers came with, that fixed it right up.
It is true that components need a lot of power, I wouldnt expect them to sound good off any h/u without an amp.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
Front Speaker Install rrclimber YJ Wrangler Technical Forum 4 01-16-2010 10:10 PM
Anyone have a Tuffy front speaker box... tomesd YJ Wrangler Technical Forum 6 09-07-2009 11:33 AM
03 front speaker dave's jeep TJ Wrangler Technical Forum 3 08-01-2009 09:16 PM
90 YJ Front Speaker Installation Boulders23 YJ Wrangler Technical Forum 7 02-08-2009 10:41 PM
Front speaker size? Drock TJ Wrangler Technical Forum 7 01-28-2004 02:42 PM
