front and rear bumper - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > front and rear bumper
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueComponent speaker deal for your dash - NalinMFG
Unread 07-23-2014, 12:02 AM   #1
yycwrangler
I have purchased a rear and front motion sensor system for my 2014 JKUS. Can anyone tell me if they have done this before and where they drilled and placed their sensors (4 front and 4 back).
If you haven't done it before can you give me an idea what's behind the bumper. Obviously it would be redundant to drill a hole and run into metal behind the plastic cover. Is there spots that have no metal be hid the plastic bumpers
Any help would be greatly appreciated
Cheers
Al
yycwrangler is online now   Reply With Quote
Unread 07-23-2014, 11:49 AM   #2
Mlaughlin8
1980 CJ5
The rear bumper is only about 7lbs of plastic... It's not a bumper at all, no metal at all! I think it's only a cosmetic frame cover... The front, I'm not sure about as I have not removed it yet. Due to my barricade hd front bumper still being on back order...
Mlaughlin8 is offline   Reply With Quote
Unread 07-23-2014, 06:00 PM   #3
mpd2434
2014 JK Wrangler
Nope front bumper is the same as the rear, all plastic.
mpd2434 is online now   Reply With Quote
Unread 07-23-2014, 06:15 PM   #4
Demp
The front bumper has some thin spots as it does have a metal backing inside. This plastic bumper is attached to this piece, which then bolts to the frame. A quick Google Images search of "wrangler jk front bumper removal" will have several results showing this piece.
The rear bumper is entirely plastic with a couple metal threaded inserts to hold it on.
I've since discarded mine so I cannot get an accurate measurement. I've seen a few do prox sensors in the rear bumper but never the front.
Demp is online now   Reply With Quote
Unread Yesterday, 12:18 PM   #5
222Doc
No the front is nothing like the rear. Front has a plastic cover over thin metal.
Th rear is all plastic excepting some hanger hardware.
[URL=http://www.bullhead4wheelersinc.com[/URL]
222Doc is offline   Reply With Quote
Unread Today, 07:04 AM   #6
yycwrangler
Thanks guys..This is very helpful..Have you seen a JK with proximity sensors for back up and forward..If so do you happen to remember where they were placed
Cheers
Al
