Front End Question - JeepForum.com
post #1 of 21 Old 09-21-2013, 08:10 AM Thread Starter
Drummer63
JK Wrangler
Front End Question
Hello everyone. I have a 2007 4DR Jeep Wrangler Unlimited Sahara. I am having issues with minor shaking at the front end. This normally occurs when speed reaches 55 MPH. I had the tires rotated and balanced. I also had the alignment checked, its fine. Any suggestions offered will be greatly appreciated. Thank you.
Drummer63 is offline
post #2 of 21 Old 09-21-2013, 08:41 AM
JTPhoto
JTPhoto's Avatar
Speed related shakes are always attributed to rotating mass. If you can recreate the shake at always the same speed then that's what you have. Therefore it's either tire and wheel or driveshafts.
You could have a tire or wheel that's bent or out of round, wheel balance may not always fix. Rotate the tires again using the spare in see if that changes or gets rid of the shake.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #3 of 21 Old 09-21-2013, 09:36 AM
Filthy-Beast
My LJ had bad wheel bearings that caused the shimmy at speeds of 53 to 60 and then would smooth out at 70.
Planman thread will help you find it. http://www.jeepforum.com/forum/f96/d...bbles-1052221/
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #4 of 21 Old 09-21-2013, 09:46 AM
invest2m4
Try the Northridge 4x4 bolt kit. Replaces the LCA bolts and track bar bolts with 9/16 bolts (stock bolts aren't the right size). Just did it on my 2013 and it made a notable difference and fixed an issue I was having. $40 and an hour of your time. It's surprising how sloppy the stock bolts feel in there.
invest2m4 is offline
post #5 of 21 Old 09-21-2013, 09:47 AM
invest2m4
Originally Posted by Filthy-Beast
My LJ had bad wheel bearings that caused the shimmy at speeds of 53 to 60 and then would smooth out at 70. Planman thread will help you find it. http://www.jeepforum.com/forum/f96/d...bbles-1052221/
Adding to my comment about the bolt kit, Planman recommends it in his video.
post #6 of 21 Old 09-21-2013, 09:59 AM Thread Starter
Drummer63
JK Wrangler
Thank you for your comments.
Jeff, I will do the easiest first and follow your recommendation of rotating the tires.
Again, thank you.
post #7 of 21 Old 09-21-2013, 11:02 AM
JTPhoto
JTPhoto's Avatar
No problem, I hope that solve your problem. Tire rotation is cheapest and easiest place to start. Bolt kits and suspension parts have absolutely nothing to do with speed related shimmies and shakes. Suspension related shakes will/can occur at any speed and cannot be recreated at any certain speed. Speed shakes are rotational mass related found in driveline parts past the transmission/transfer case such as tires, wheels, driveshafts etc.
^^Jeff^^
JTPhoto is offline
post #8 of 21 Old 09-21-2013, 11:22 AM
Filthy-Beast
True, but an imbalanced tire can trigger a suspension related shimmy at a certain speed. On a 2007 it would be a good idea to walk through Planman's guide and check all the typical places for loose or worn parts. Odds are very high you'll find some parts that need correction and if left they will only get worse.
For Sale:
post #9 of 21 Old 09-21-2013, 11:29 AM
JTPhoto
JTPhoto's Avatar
You just said it !!! "An unbalanced tire can trigger" ... The unbalanced tire starts the DW at a certain speed. If you didn't have loose parts it would only stay as a minor tire shake or shimmy. That tire is still the rotational mass in the scenario...
^^Jeff^^
JTPhoto is offline
post #10 of 21 Old 09-21-2013, 11:39 AM
JTPhoto
JTPhoto's Avatar
We need to help the OP find this problem before changing parts that can possibly compound the problem. Then he will really be lost.
Don't get me wrong, with it being an 07 I strongly suggest having the front end thoroughly inspected for worm and loose parts, however, we need to sort out one thing at a time.
I never change more then one part at a time when I am modifying or trouble shooting. If you change more then one thing at a time you will never know the true effect of each part on the rest of the system.
^^Jeff^^
JTPhoto is offline
post #11 of 21 Old 09-21-2013, 11:42 AM
Filthy-Beast
Perfectly balanced tire no shimmy, tire with mud shimmy at 53MPH, clean tire no shimmy. Perfect balance and no shimmy didn't change the fact that the wheel bearings were worn.
My point is do the preventive maintenance of walking through Planman's guide. I'm not telling the guy to spend money and throw parts at it. Just to check for worn parts.
For Sale:
post #12 of 21 Old 09-21-2013, 11:50 AM
JTPhoto
JTPhoto's Avatar
Perfectly balanced tire no shimmy, tire with mud shimmy at 53MPH, clean tire no shimmy. Perfect balance and no shimmy didn't change the fact that the wheel bearings were worn. My point is do the preventive maintenance of walking through Planman's guide. I'm not telling the guy to spend money and throw parts at it. Just to check for worn parts.
You are correct, a rock stuck in the tread of an M/T tire can throw a tire out of balance, but bearings are not rotational mass and will not cause speed related wobble. They can cause a well balanced tire to wobble at any speed just like any other steering or suspension components. Like I said, I'm not saying he shouldn't check other components for wear, just solve this one first.
^^Jeff^^
JTPhoto is offline
post #13 of 21 Old 09-21-2013, 01:10 PM
brighton
2010 JK Wrangler
I had a speed-related shimmy (between 50 and 55 mph) for about 6 months after I installed new tires. To try to track down the cause of the shimmy I checked the suspension, ball joints, etc. and nothing was loose or worn. I had my tires rotated and balanced several times. Then I took the advice to have my tires road-force balanced. No more shimmy.
'10 JKU Mango Tango 6sp
brighton is offline
post #14 of 21 Old 09-22-2013, 02:59 PM Thread Starter
Drummer63
JK Wrangler
Thank you for all the input. I will post an update to let all know what was found/determined.
post #15 of 21 Old 09-22-2013, 08:45 PM
Millermagic
I have a shimmy on my XJ at 55 MPH. Doesn't matter what set of tires I have on it (have 3 sets). I have an entirely new front axle (different story), new ball joints, wheel bearings and balanced tirese.
It just happens.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
