Front end hops in 4wd. - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Front end hops in 4wd.
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-06-2010, 08:25 AM   #16
paul84043
Originally Posted by tjkj2002 View Post
You could possibly have a lunckbox locker in the front or a auto locker like the Detroit.Pull the front diff cover and look.
If this were the case would this still be a malfunction?
paul84043 is offline   Reply With Quote
Unread 12-06-2010, 09:20 AM   #17
MacK
2010 JK Wrangler
Jeep - 4x4 Basics - How Jeep 4x4 Systems Work - Command-Trac - 4WD SUVs
"Vehicle shudder and tire scuffing due to a binding condition in the driveline. Usually caused by operating in basic 4WD or part-time 4WD modes on dry pavement."
You aren't on slick enough surfaces.
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline   Reply With Quote
Unread 12-06-2010, 09:21 AM   #18
nwbronco
Imped gave the most simplistic response I've ever seen. Good job! Any type of auto locking device, lunch box or not, will extend the single drivetrain out to the wheels. All wheels trying to turn in unison, something has to give.
Bob K.
nwbronco is offline   Reply With Quote
Unread 12-06-2010, 07:48 PM   #19
RockyClymer
RockyClymer's Avatar
I disagree that "any type of auto locking device will extend the single drive train out to the wheels" - an auto locker only is supposed to lock up when one wheel spins faster than the other and forces the clutch pack or other inertia activated device to partially lock the differential - ie limited slip or such or fully like a detroit auto locker, then I would agree it does, - normally they are not supposed to be locked.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 12-07-2010, 06:49 AM   #20
nwbronco
It's all good. Auto lockers are that quirky though. They load and unload at the most inconvenient times. I have an 86 Bronco with a Detroit Dana 60 in the rear, and a Dana 44HD with a Detroit EZ (lunch box) in the front. And, from experience, they will engage at the slighest wheel speed differential, and then bind up and stay that way until the wheel speed in matched, or they let go with a pretty good bang. A turn is just the type of wheelspeed offset that would cause it to lock. Since it is spring loaded, it shound bind and then release. Not always the case though. I've seen Detroits bind up and then let go and destroy a front axleshaft.
Bob K.
