front end feels loose - JeepForum.com
post #1 of 10 Old 08-31-2010, 03:27 PM Thread Starter
newjk
front end feels loose,steering stabilizer replaced under warrenty, getting out my torque wrench, how often does front end need to be torqued and can i upgrade parts. 2008 unlimited, totally stock. tks evryone
newjk is offline
post #2 of 10 Old 08-31-2010, 04:28 PM
1222
RIP John
1222's Avatar
If it’s stock you shouldn’t even need to re-torque because they use loctite on all nuts and bolts from the factory.
(2011-2016)
1222 is offline
post #3 of 10 Old 08-31-2010, 04:31 PM
ncb
Raise the front end on jack stands, and check the suspension out. Give everything a good tug to see what's loose. Inspect the track bar mounts on both ends. Maybe a broken weld.
ncb is offline
post #4 of 10 Old 09-03-2010, 07:57 PM
Unlimited2010
i have had this clunk in my steering for the past 5 months! happens when you are going slow and wigle the steering wheel and when going 30-40 mph (in 3'rd gear auto) and give it a little gas you can hear/feel it.......
there is slop somewhere????????? it is a 2010 unlinited with almot 8K miles now.
anyone else have these symptons. the master mechanic at a dealer can't feel it..........might have t bring it back to the dealer i purchased it at........
-R
Unlimited2010 is offline
post #5 of 10 Old 09-03-2010, 08:12 PM
1222
RIP John
1222's Avatar
-R
Not sure if this is your problem but you might want to take a look anyway. Oh, and by the way, them claiming they can’t hear or feel it is unfortunately common with some dealers. Demand to go on the test drive with them so they will notice it. http://www.jeepforum.com/forum/f96/s...cause-1023438/
(2011-2016)
1222 is offline
post #6 of 10 Old 09-04-2010, 04:30 AM
Unlimited2010
took him for a ride and he felt nothing!!!!!!!!! will check out you ther link
thanks.
-R
post #7 of 10 Old 09-04-2010, 10:57 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Here is another possibility straight from the (old) F.A.Q. http://www.jeepforum.com/forum/f96/j...8/#post2754158
Go to the new F.A.Q. for lots of great info
Good luck and check everything
Jim
JLC08JK is offline
post #8 of 10 Old 09-04-2010, 11:09 AM
sledding55
2010 JK Wrangler
my 2010 started to clunk also when i would hit bumps, It turned out to be just a loose bolt on the track bar. Maybe check that out just look under it and get some one to jump on the bumper to see if you can feel or notice any play or movement in any part of the front end.
sledding55 is offline
post #9 of 10 Old 09-04-2010, 11:26 AM
1222
RIP John
1222's Avatar
thanks.
-R
I had the same problem with the dealer too. What I did was to have him and me go to a parking lot where there were speed bumps and to keep going over them and turn the steering wheel left to right as he did. He kept saying that he couldn’t hear or feel anything but finally it got so bad that he couldn’t lie anymore. If I were you I would go straight to the service manager and ask for another test drive with you included.
(2011-2016)
1222 is offline
post #10 of 10 Old 06-03-2011, 07:35 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
I got the problem fixed thanks to 1222's post:
http://www.jeepforum.com/forum/f96/steering-knock-another-cause-1023438/
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
Something feels like it is loose under my jeep.... Xander TJ Wrangler Technical Forum 3 04-14-2010 08:12 AM
Front end feels 'loose' when turrning all the way jeepinJayO TJ Wrangler Technical Forum 3 03-23-2010 07:24 PM
Feels something loose in steering marzak4d JK Wrangler Technical Forum 4 07-18-2009 10:55 PM
Feels like front end is loose over bumps????? JERSEYJK JK Wrangler Technical Forum 3 05-13-2009 05:05 PM
steering feels loose ohhpe YJ Wrangler Technical Forum 5 02-26-2005 03:29 PM
