front driveline angle - JeepForum.com
post #1 of 3 Old 11-02-2012, 09:57 PM Thread Starter
dolson60174
I have a buddy that has a 2008 JK 4 door. He has a 4" Rough Country lift that was installed from the previous owner. He now has an issue that his Ujoint on the transfer case is failing becasue the angle is too steep. What is needed to even to fix this? I know there is a part for this but cant think of what it is to fix it. Thanks!
-It's not how far you go, it's how go you far.
-Dave Marschack
dolson60174 is offline
post #2 of 3 Old 11-02-2012, 10:04 PM
Coolcatracing
He needs a double cardan drive shaft. There's plenty of different ones available, he'll also need to adjust the pinion angle for that kind of lift and the DC driveshaft needs a different angle than a single cardan shaft so he'll need adjustable control arms.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
post #3 of 3 Old 11-03-2012, 08:51 AM
maniacal_rick
If he doesnt have Adjustable Control Arms he will have a problem with just about any driveshaft. He needs to correct the problem first, which is pinion angle. UCA's will correct that.
2012 2Dr JK - Metalcloak - Currie - Prorock - ARB - Poison Spyder - RCV - Synergy - Etc...
maniacal_rick is offline
