Front door's question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Front door's question
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!
Unread 07-05-2013, 07:48 AM   #1
Breitling
Is it possible to adjust front doors locks that I don't have to slam them every time I need to close them? Both rear doors are fine, only front are required additional power, is it some sort of known issue? Thanks!
(answer with take them away is not valid )
2013 Jeep Wrangler Unlimited Sport S, hardtop, white, duratracs, tons of mopar parts
2012 Mercedes Benz C350 coupe, white
Breitling is offline   Reply With Quote Quick reply to this message
Unread 07-05-2013, 08:23 AM   #2
xflstl
2010 JK Wrangler
You could adjust the striker's out just a pinch, that might help.
xflstl is offline   Reply With Quote Quick reply to this message
Unread 07-05-2013, 08:43 AM   #3
JIMBOX
Roll one window done 1/2"--
If you play with the door/fit mechanics---it'll probably start leaking, when it rains--if it already does--no biggee !
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote Quick reply to this message
Unread 07-05-2013, 12:54 PM   #4
AlbertaJeeper
I think its just the air trapped in the vehicle that is making it difficult for the last door to be closed. Either roll down the window a bit, pop the top off, or just embrace the slamming!
AlbertaJeeper is online now   Reply With Quote Quick reply to this message
Unread 07-06-2013, 08:14 AM   #5
BadHammers
You don't have to slam. Just picture the door jamb being a few inches inboard of its actual position. If you continue to apply closing force after contact has been made, the door will latch completely without having to slam it. Chrysler vehicles with electric locks and windows need as little door impact as possible.
Simon Alexander
'14 WK2 Overland
'13 JKU Rubicon
Jeeps past 01 XJ, 08 JK, 11 KK
BadHammers is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 09:59 AM   #6
Breitling
It is good technical suggestion but not practical, people I am driving usually don't care about all this details much.
Unread 07-07-2013, 10:39 AM   #7
1222
Make mine a Jeep!
1222's Avatar
Either live with it or do like JIMBOX suggested and crack a window open if bothers you that much; itís just the way it is and nothing will change that fact. Missing with the door lock mechanism will in most likelihood lead to other problems. Oh by the way make sure you have some electrical tape standing by because that will be needed next concerning your doors, all four of them.
1222 is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 07:46 PM   #8
IlikeTurtles
I came here to seek an answer to this as well. My wife's '13 unlimited front doors are a ***** to close. Rear doors are no problem, front doors seem like they have not seated properly. Will try to crack the window and see if it helps.
IlikeTurtles is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 08:12 PM   #9
Wavedatya
2010 JK Wrangler
It's normal. With my hard top on I have to slam the doors even passenger always have to be reminded and leave doors open. It's a tight seal that's all. I know because I almost submerged my jeep in 7 feet of water And no water came in!!!!!
I never have tht issue with soft top or if a window is open. And there will be a transition when you have the soft top and don't have to slam them.
The best part is when you hop in a buddies truck and slam the door. And they look at you like "really?" It becomes habit. Another quirky part of owning the best vehicle in the world!!!!
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 10:09 PM   #10
AlbertaJeeper
The biggest issue aside from the tight seal is the doors being very light compared to a regular vehicle door. Same speed of swinging+less weight=less momentum! And my 5'2" girlfriend just said if she can close them anyone else should be able to as well!
