Front Dana 44 - JeepForum.com
post #1 of 25 Old 06-01-2012, 05:44 AM Thread Starter
cyberpyrot
Front Dana 44
I have a 2012 Jeep with a dana 30 in the front how difficult/Expensive would it be to bump it up to a 44?
cyberpyrot is offline
post #2 of 25 Old 06-01-2012, 06:28 AM
TheHuntsman
Good question. I look forward to hearing answers and opinions as I plan to eventually upgrade my front axle to a 44, and my rear to a 60 eventually.
TheHuntsman is offline
post #3 of 25 Old 06-01-2012, 06:46 AM Thread Starter
cyberpyrot
If I do it or get it done I will document my trials.
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
post #4 of 25 Old 06-01-2012, 06:54 AM
TheHuntsman
Awesome! Thanks!
post #5 of 25 Old 06-01-2012, 08:56 AM
222Doc
222Doc's Avatar
for the cost of going to 44, not worth it. might as well go 60. no reason to do any of this unless you wheel hard core trails with 37+. i would bet that no one in this is going to be running 4+ in a 012.
222Doc is online now
post #6 of 25 Old 06-01-2012, 09:00 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Agreed, and even in that instance, you're mostly inhibited by a smaller pinion than the D44. Sleeve, gusset, and axle shafts for a profound improvement at a less expensive cost than buying, rebuilding, and installing an assembly.
I personally wheel with two rigs that have armored D30s, one TJ HP, and one JK. Both do just fine even on the "hard core" trails.
Mol is offline
post #7 of 25 Old 06-01-2012, 09:04 AM Thread Starter
cyberpyrot
Thanks for the advice I guess I will keep it stock and start working on a small lift
Thought of the day
post #8 of 25 Old 06-01-2012, 09:10 AM
Mol
Mol's Avatar
I'm not saying that there are not better axles out there...obviously there are. But cost:benefit:use, well you get the point.
Mol is offline
post #9 of 25 Old 06-01-2012, 10:16 AM
FastHotRod
I saw that Quadratec has a Rubicon Dana 44 front axle for $3099.99
An extra $130 will get you the wiring harness and switch plate for the electronics. But as these guys said, you will spend less to improve your Dana 30.
Like these guys said, if you are looking to go hard core then stepping up to a Dana 60 may be a better bet. There are a few companies out there that have brackets and kits, and you can even buy complete axles if that's your thing.
I've seen JK specific Ford 9/Dana 60 front axles from Currie for about $5k that are complete from hub to hub. If you wanted to spend less, you can get a Ford 9/Dana 60 front axle for about $3,500 ~ $3,800 if you decided to use your stock outer knuckles. More info here.
Good luck with whatever you decide to do.
FastHotRod is offline
post #10 of 25 Old 06-01-2012, 10:37 AM
Alaska-HWY JK
Go to Northridge 4x4 website to price out a Dynatrac Prorock 44.
Alaska-HWY JK is offline
post #11 of 25 Old 06-01-2012, 11:17 AM
SubAtomicGenius
2011 JK Wrangler
Everything is relative for the front axles, and like Molshove said, you have to balance intended use with cost.
D30 sleeved and gusseted for around $150-250 not incl. labor. Re-gear and locker extra. Cheap - but downside is small ring gear and bent tubes/C's if you don't weld them up. However, most won't have issues unless you severely beat your rig.
Mopar "Rubi" D44 front axle assembly ball-park $3000, comes with 4.10's and locker. Downside: axle tubes and outer "C's" are same size as D30, so you're probably better off sleeving and gusseting, too. Plus you'd either have to re-gear your current rear D44 or put new gears in the front D44. So, factoring all of this in, you're better off to go to the next option...
ProRock 44 ball-park $3800-4000 with gears and locker. Downside: $$ price. However, when compared to the price paid for a Mopar D44, the base ProRock 44 has 5/16" axle tube walls and beefy C's that are much stronger than Stock D44. Much like a stock D44 with beefier tubes, mounts and 1-ton C's. Spend an extra $80 and you get massive 1/2" tube walls that are 182% stronger than a stock D44!!! IMHO, the best upgrade if you are looking for a D44 from a D30.
Teraflex TERA44 is ball park the same as the ProRock 44, however I don't believe Teraflex sells their D44 assembled - so you have to do this yourself or have it done (possibly more expensive than Dynatrac then). They use large OD tube walls with standard thickness to produce a D44 that has a higher strength-to-weight ratio than sleeving and/or getting heavy-walled tubes.
ProRock 60 ball-park $6000 with gears and locker. Downside: $$$ price/weight. Totally awesome though - even if nearly 1-1/2 times cost of the ProRock 44.
Then of course you can upgrade with RCV CV shafts, 1350 Yolks and Driveshafts, and rebuildable ball joints.... and another $2500...
SubAtomicGenius is offline
post #12 of 25 Old 06-04-2012, 09:42 AM
JKChris
2015 JK Wrangler
I am in a similar situation as the OP. I am considering bumping my D30 up to a D44. I just recently lifted and added 35s. I am in looking to re-gear and add lockers all in one shot. Right now, my Jeep is my only vehicle so I am not looking to badly abuse it in the short term. My long term goal, however, is to eventually buy another car and keep the Jeep as a toy. Then, I will be more tempted to beat on it. So, my question is this...
Since I am in the position where I am going to need a re-gear and lockers (front and rear), am I a better candidate for the front axle upgrade that I could have built with what I want, or do you still think I should stick with my D30 and build it up (gears, locker, sleeves, gussets)?
Thanks for the input
Chris
JKChris is offline
post #13 of 25 Old 06-04-2012, 09:53 AM
Mol
Mol's Avatar
Chris
Price both options out...if you're going to throw a 44 in, do it the right way and buy a prorock 44. $4,500 with RCVs, locker, gears. $3,500 with chromoly instead of RCVs.
Your 30 built, without labor, is going to be about $2,800 (including gears for rear, but no rear locker) with RCVs, or $2,300 with chromoly.
Obviously labor will change these numbers substantially if you're not handling the work yourself.
If the $1,000 ish difference doesn't hurt ya, and you're going to use it, go for the swap. If you do a little soul searching, and you think you won't hold onto it and make it a toy, but trade it in, or sell it, you're spending a lot of money on stuff you won't get back. That's up to you
Mol is offline
post #14 of 25 Old 06-04-2012, 10:06 AM
JKChris
2015 JK Wrangler
Thanks for the reply.
I know I could always change my mind, but I really love that Jeep. I just don't see myself getting rid of it anytime soon. I am really leaning toward the front 44. Plus, I don't know if there are people out there looking for a D30, but maybe I could minimize the cost a little by selling the stock axle.
Thanks for your input.
Go Bucks!
JKChris is offline
post #15 of 25 Old 06-04-2012, 10:38 AM
Mol
Mol's Avatar
Go Bucks!
Good luck selling the 30....lol
I have never kept vehicles long term, other than the old family suburban...but I have found that with every dollar I spend on the JK, it becomes more a part of the family. I will be burried in mine, with several others I'm sure.
Moral of the story...spend lots of money, and you'll definitely keep it
Mol is offline
Question about Dana 30 to G2 Dana 44 front swap snowcrash TJ Wrangler Technical Forum 31 04-08-2013 07:29 PM
aftermarket front dana 44 vs. built dana 30 bigwyrm TJ Wrangler Technical Forum 9 04-04-2011 12:02 PM
Can an Aussie Locker for a Dana 35 be altered and used in a Dana 30 Front JGEORGE TJ Wrangler Technical Forum 3 02-18-2011 08:03 AM
Dana 35 Rear, Dana 30 Front Gear Ratios robobrown YJ Wrangler Technical Forum 0 08-31-2010 03:30 PM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 08:20 PM
