Freedom Top Panel Pin is Loose. - JeepForum.com
post #1 of 4 Old 06-16-2009, 07:53 AM Thread Starter
gwar11d2
2009 JK Wrangler
So after this weekend I'm taking a long roadtrip and decided to put the hardtop back on. When putting the Passenger side on I noticed the 'alignment' pin that sits in the sportbar above the door is now loose out of the panel. Looks to me there is no way to really tighten it back in.
Anyone else run into this issue? I'm gonna take it into the dealership and hopefully they will fix/replace the issue.... I swear I didn't drop the panels or anything, unless my dog started to chew on it or something, but I didn't see any bite marks, she usually saves the chewing for house door trim
09 JK Jeep Green Sahara Unlimited / Teraflex 2.5" Spring-Shocks / 35's x 16" Level 8 Trackers/ Aussie Locker Front / 5:13's
My Build Thread:
gwar11d2 is offline
post #2 of 4 Old 06-16-2009, 10:41 AM
NYCJohn
2009 JK Wrangler
Have you tried to turn it as if it is a screw? Maybe it came loose that way? Not sure if it is welded in tho..
Good luck.
NYCJohn is offline
post #3 of 4 Old 06-16-2009, 11:38 AM Thread Starter
gwar11d2
2009 JK Wrangler
Good luck.
Yah, I tried screwing it back in like it was a screw which seemed to have fixed the problem once, but it doesn't seem to hold... I think there might be something inside the panel that isn't right. I'm pretty sure the dealership will probably have to order me a new panel because it doesn't look like it comes apart
My Build Thread:
gwar11d2 is offline
post #4 of 4 Old 06-16-2009, 11:42 AM
omnicitadel
Where Did The Weasle Go?
omnicitadel's Avatar
warranty time... try and see if you can keep the old pannels just in case once the bumper to bumper runs out
2008 JK-Xs Steel Blue Metallic Dual Top
Mods: Performance Accessoires 1" Body lift, 2.5" Teraflex Lift, 35x12.5x17 Dunlop Radial Mud Roaver, Alpine iDA-X100 Head Unit, Infinity REF6022I 6.5" Front and Rear Speakers.
Docket: Shrockworks Rock Sliders, Rock Hard 4x4 Skid's (all of them), Front and Rear Bumpers (undecided), Winch (undecided)
omnicitadel is offline
freedom top panel splang JK Wrangler Technical Forum 13 05-08-2015 09:21 AM
Freedom Top wingnuts coming loose?? MPants89 JK Wrangler Technical Forum 3 06-30-2009 01:47 AM
Freedom Panel stash bag Automatic Otto JK Wrangler Technical Forum 12 04-23-2008 11:11 AM
Freedom Top Panel Storage NJ_WVUGrad JK Wrangler Technical Forum 12 09-25-2007 03:49 PM
Creakin' Freedom Top Panel rchs.band JK Wrangler Technical Forum 3 08-10-2007 05:28 AM
