Freedom top - getting front pieces on evenly - Page 2 - JeepForum.com
post #16 of 29 Old 07-24-2011, 09:14 PM Thread Starter
jett78
2011 JK Wrangler
Take it off or just loosen the bolts and re-tighten? As soon as I push it down, the area towards the middle wants to push towards the front of the vehicle
jett78 is offline
post #17 of 29 Old 07-24-2011, 09:14 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
I would take it back to the dealer and ask them to show you how to put them on properly.
When they aren't able to you can ask what they are going to do about it!
Good luck
Jim
JLC08JK is offline
post #18 of 29 Old 07-24-2011, 09:21 PM Thread Starter
jett78
2011 JK Wrangler
I gotta go pick something up from them on Tuesday anyway...
But check this, if I try to force it to where they are aligned, then the knob won't line up
jett78 is offline
post #19 of 29 Old 07-24-2011, 09:23 PM
williewvr
Need to make sure pins are seated in the holes at front of rear section then tighten evenly. Remember they are trying for production numbers. If your a lineman about the 100th time a day you put a top on you might not care its seated right.
williewvr is offline
post #20 of 29 Old 07-24-2011, 09:28 PM
doosh
2010 JK Wrangler
Mine is the same, one is a couple of mm closer to the windscreen than the other. Pretty sure it came off the lot like that. I've had them on off, soft top on, hard top back on now and every time they go back on, it looks like that.
Have had no troubles with water leaking in or rain noise - I just accepted it.
doosh is offline
post #21 of 29 Old 07-24-2011, 09:29 PM Thread Starter
jett78
2011 JK Wrangler
Thanks for your help, I'll try that tomorrow after work... getting a bit late and frustrating
jett78 is offline
post #22 of 29 Old 10-22-2014, 06:39 AM
eschwam
Did you end up fixing it? I have the same problem. It's driving me nuts!!!
eschwam is offline
post #23 of 29 Old 10-23-2014, 10:30 AM
01Mastiff
2014 JK Wrangler
With the rainy season approaching I would buy a scuba outfit. Mine lines up correctly and I have small waterfalls inside. Very peaceful to listen to but still somewhat annoying. I have fixed this by drinking which also has a calming effect.
01Mastiff is offline
post #24 of 29 Old 10-23-2014, 10:32 PM
SoK66
2009 JK Wrangler
I virtually never take the things off, but I had to remove them and slide the top back to install a Rock Hard 4x4 cage. Without going off on a tangent here, the bars for the cage were too short and pulled the factory overhead bars out of alignment. There are little indexing holes in those bars that correspond to some plastic posts on the underside of each Freedom Top panel. The pins drop in those holes, etc. I learned there are adjustment bolts for the side bars, accessible through the upper of two holes in the plastic trim pieces at the upper corners of the windshield frame. They are usually rather loose. Tighten them to pull the bars outward, loosen to let the bars float inward a bit. When you get them right you should be able to drop the little plastic guide at the outer front edge of the top panel into the slot in the weatherstrip and have the panel drop into place. If they are aligned right the gaps should be relatively even in front, rear and down the center. TRICKY to get right.
Back to my Rock Hard 4x4 cage install, the over head bar bent the side bars inward and the adjuster bolts wouldn't correct the misalignment. To get the tops to fit right I had to slot one of those indexing holes enough to allow the top to center.
Jeeps: Where my 401(k) went to die!
SoK66 is offline
post #25 of 29 Old 10-24-2014, 08:27 AM
JIMBOX
I had trouble with the forward drivers side freedom top interference/w the Rockhard too-
Since it had been a "no leak" top for years--I didn't change any of the top alignment/seals/pins--
I relieved (Dremel) the inside outter face of the drivers top, untill I could fit a playing card around the Rockhard fitting-
The top fits fine, no leaky and the Rockhard is solid as a rock !
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #26 of 29 Old 10-25-2014, 07:45 AM
oscrfsh
I'd like to sew a pick of the blocks that flip down on the front freedom panels . I don't think I have those on my 2010
oscrfsh is offline
post #27 of 29 Old 10-25-2014, 08:04 AM
JIMBOX
Just take your hardtop Freedom panel off--and look at the rear underside-
What do you think the two rear thumbscrews screw into ?
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #28 of 29 Old 10-25-2014, 12:07 PM
Jiblet
If anyone is having trouble seating the freedom panels in a watertight manner, it's possible the rest of the hard top is to blame.
Try loosening the tub bolts to relieve any stress, then install the freedom panels, then tighten the tub bolts.
The top has guide pins but only at the front corners. It could be skewed enough to allow water in.
Jiblet is offline
post #29 of 29 Old 10-27-2014, 03:33 PM
VICTIM_OF_PAIN
VICTIM_OF_PAIN's Avatar
Make sure all weatherstripping is tucked inside and not binding up. That will push a panel back a bit.
Ex - 2001 Wrangler, 2" BB, 32" BGF AT's. JKS Quicker Disconnects, Oil Pan Skid, Steering Box Skid. Hard Top, Soft Top, Safari Top, Olympic Mountaineer Rack.
Current - 2008 Unlimited Wrangler Rubicon. Rock Krawler Stock Mod 2.5" lift, 35x12.50x15 Cooper STT's on Pro-Comp D-Windows, Husky Floor Liners, Mastercraft Grab Handles, Weathertech Side Window Deflectors, Hitch mounted D-Ring, Rancho Oil Pan Skid, Rugged Ridge E-Disco Skid, and a Skid Row Evap Canister Skid plate.
It is better to keep one's mouth shut and be thought a fool.... than to open it and remove all doubt.
VICTIM_OF_PAIN is offline
freedom top , install , straight
Freedom Top 1 or both Front pieces off? oaklane JK Wrangler Technical Forum 6 04-17-2008 12:58 PM
Who Removes Pieces of their Freedom Top at Least 3x/Week? YoungTurk JK Wrangler Technical Forum 6 03-04-2007 01:51 PM
rubber pieces on the front bumper help onemoredrinkk TJ Wrangler Technical Forum 7 10-16-2006 12:57 PM
Flares not taking paint evenly jdvailco TJ Wrangler Technical Forum 10 04-24-2006 09:25 PM
Removing the 2 Rubber Pieces on the Front Bumper yurmom22 TJ Wrangler Technical Forum 2 02-14-2004 10:37 PM
