Freedom hardtop Wind noise - JeepForum.com
post #1 of 8 Old 03-08-2010, 06:53 PM Thread Starter
NJelectrik1
2010 JK Wrangler
does anyone know how to solve the wind noise problem with the 3 piece freedom hardtop?
it seems to whistle at around 45mph , which goes away and becomes just more of a a wind noise at higher speed , sort of like driving with a window open a tad
any advise is greatly appreciated
NJelectrik1 is offline
post #2 of 8 Old 03-08-2010, 07:00 PM
Grizzly1
2010 JK Wrangler
I have a bit of wind noise myself, but I dont think I have any "whistle". I attribute it to the windshield being at a 90 degree angle..... Zero areodynamics..... Thin rook with no insulation....
There is always going to be some wind noise.
Still, if yours is worse than normal, ensure the seals on your top are good, and ensure you are attaching them properly. Check all your door seals as well. I am sure therewill be more comments from others here. There is a lot of knowledge on the forum, I hope it helps.
Semper Fi
Grizzly
Grizzly1 is offline
post #3 of 8 Old 01-08-2012, 01:48 PM
aaluotto
I recently am having the same problem. All I can think is the rubber seal where the two tops meet is pushed down.
aaluotto is offline
post #4 of 8 Old 01-08-2012, 07:33 PM
Charles
2017 WK
Remove top and doors, drive 70 MPH. You will then understand wind noise. Re-install hard-top. Problem solved.
Charles is offline
post #5 of 8 Old 01-09-2012, 07:38 AM
Dale_K
I've read some threads where people get a whistle that's actually coming from the little gap between the windshield and frame. Mostly it's people who recently had their windshield replaced but it might be worth checking out since it's so easy. Temporarily run some masking tape around the perimeter of the glass and cover up the gap, then take it for a test drive.
You could probably test the top-to-windshield seal the same way. Put some 2" masking tape over the seam and go for a drive.
Dale_K is offline
post #6 of 8 Old 01-09-2012, 07:44 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Trying attaching a thicker piece of rubber as a shim between the latches and the metal hoops at the front of the freedom top panels/at the top of the windshield, to snug it down a little tighter.
Mol is offline
post #7 of 8 Old 01-09-2012, 08:45 AM
mattlago
I had this happening from my passenger area. Have noticed that if i loosen and re attach it will make some change in the sound.
Wouldnt bother posting something so simple, but I just noticed a couple of days ago that the passenger door molding was not in its proper place so not making the best seal. As I never sit in there, I never checked. So maybe something to look at.
behold a pale horse: and his name that sat on him was Death, and Hell followed with him...
2012 JKU RUBI PALE TAN
mattlago is offline
post #8 of 8 Old 01-09-2012, 08:47 AM
Jiblet
See if you have gear blocking the tail gate vents.
I get a lot more wind noise when those are blocked.
Jiblet is offline
Hardtop Wind Noise. DUTCH97501 TJ Wrangler Technical Forum 11 09-11-2009 01:10 PM
Excessive wind noise - driver side freedom top panel laka JK Wrangler Technical Forum 2 09-07-2008 09:58 PM
No more hardtop wind noise hogzilla YJ Wrangler Technical Forum 3 12-14-2006 07:41 PM
Wind noise from hardtop. bruker TJ Wrangler Technical Forum 23 10-17-2006 02:56 PM
Wind noise on an 04' TJ hardtop? franco802 TJ Wrangler Technical Forum 3 11-01-2003 10:54 PM
