Fooled by the MPG-ometer - JeepForum.com
post #1 of 39 Old 12-19-2013, 12:55 PM Thread Starter
Yendor
WTH, the first couple of tanks full, it was really close. This last tank, it said 18.4, and was really 16.8.
Not really that big of a deal, but if they went to the trouble of putting it in, and I paid for it, I want it to be more accurate than that.
Winter blend gas, perhaps?
Is this one of the things that can be re calibrated with a tuner?
Yendor is offline
post #2 of 39 Old 12-19-2013, 04:17 PM
4x4jkx
Mine has never been dead on accurate. Without knowing how Chrysler computes mpg on their vehicles I can't say as to why. General guess would be compounding errors in sensor readings.
I'm typically of by anywhere from .5 to 1.5 mpg
4x4jkx is offline
post #3 of 39 Old 12-19-2013, 04:24 PM
krawler510
More stop and go? More hills?
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #4 of 39 Old 12-19-2013, 04:42 PM
442Wrangler
In like Flynn.
442Wrangler's Avatar
My 08 has never worked right either. Always been .5-1.0 off. Just a retarded set up IMHO
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #5 of 39 Old 12-19-2013, 04:49 PM
Dead-On
2017 JK Wrangler
Chrysler's MPG calculator just sucks. If I reset it while accelerating or going up hill it reports a low number till I reset it again. If I reset it while going downhill or coasting it will give me a high number till I reset it. And some times it acts just whacky.
Dead-On is offline
post #6 of 39 Old 12-19-2013, 04:51 PM
ronjenx
ronjenx's Avatar
That's about how much mine has been off, too.
On systems that can be tweaked, it takes a while to get it to be accurate.
The JK system can't be tweaked. I suppose one could play with the tire diameter, but then the speedometer/odometer would suffer.
ronjenx is offline
post #7 of 39 Old 12-19-2013, 05:35 PM
HAFICON
I reset mine almost every day and it stays close, but I don't really care what is says I am going to drive my Jeep regardless..
315/70/17 Duratrac on MB Wheels
AEV 2.5 with M.O.R.E 1" body lift
Viair 450c, ARB Air lockers,
4.88's and TNT truss.
My build thus far.
HAFICON is offline
post #8 of 39 Old 12-19-2013, 07:03 PM
Tragyn
2011 JK Wrangler
Um, what's it supposed to do? You're taking an average of fuel consumed over distance traveled. If you're going down hill, you'll cover more distance while using less fuel. Of course it'll report a high MPG...
Tragyn is offline
post #9 of 39 Old 12-19-2013, 07:29 PM
Dead-On
2017 JK Wrangler
I fully understand that but the calculations are affected by when I press the reset button. I have to be on relatively flat ground and accelerating at an average speed for it to be relatively correct. If I decide to hit the reset button and let off the gas for just 5 seconds to hit it the average will read high even if my trip is hundreds of miles. It seems to be worse if I hit the accelerator. If I am accelerating when I hit it (even for a few seconds) the average will read about 2-3 MPG lower than the actual usage even if I'm driving hundreds of miles. There's something up with the initial calculation process when you hit the reset button on my JKU .
Dead-On is offline
post #10 of 39 Old 12-19-2013, 07:38 PM
Tragyn
2011 JK Wrangler
Ah, maybe you're right. I never paid particular attention. Usually I'll wait until I'm at cruising speed before resetting.
Tragyn is offline
post #11 of 39 Old 12-19-2013, 07:43 PM
JTPhoto
JTPhoto's Avatar
The documentation specifies that the system records a value averaged over the past 500 miles if you don't reset it. If I reset mine at every fill up it seems to be pretty accurate. In order for it to be accurate the speedo/odometer must be accurate as well.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #12 of 39 Old 12-19-2013, 07:50 PM
Neo1130
2015 JK Wrangler
Mine is always within .2. I will fill the tank and reset the meter...
Neo1130 is offline
post #13 of 39 Old 12-19-2013, 10:30 PM
SubAtomicGenius
2011 JK Wrangler
Could be temperature changes, cold weather, blended fuel, etc. Accuracy is also highly dependent on the driver's driving habits.
SubAtomicGenius is offline
post #14 of 39 Old 12-19-2013, 10:34 PM
ronjenx
ronjenx's Avatar
Another thing that affects the accuracy is the fact that it doesn't directly measure fuel flow.
ronjenx is offline
post #15 of 39 Old 12-19-2013, 10:40 PM
SubAtomicGenius
2011 JK Wrangler
Yeah, I can sit outside the store idling (OMG! ) while waiting for the woman and watch the MPG go down... down... down...
