fog light relay conversion for jk - JeepForum.com
post #1 of 2 Old 02-26-2007, 08:38 PM Thread Starter
Maine45
2014 JK Wrangler
Looking for fog light relay conversion for my jk Sahara.
So I can run high-beam and fog lights.
Did conversion on my 2004 tj.
Maine45 is offline
post #2 of 2 Old 02-26-2007, 11:11 PM
jdrogers
Search around, no such similar modification for the JK. You can add a new switch and relay to force the fog lights on whenever you want or you can add a relay to always turn on the fog lights whenever the high beams are on.
2002 WJ Limited, Stone White, 4.7L H.O., Quadra Drive
OME Springs, MX6 Shocks, BFG 265/70R17 All-Terrain, Level 8 Tracker Wheels
Scottsdale, AZ
jdrogers is offline
Using stock fog light switch to trigger AM light relay vohk TJ Wrangler Technical Forum 3 01-17-2010 01:50 PM
Light Relay? 911rsr TJ Wrangler Technical Forum 2 08-01-2009 10:49 PM
Fog Light Relay Nemoralis TJ Wrangler Technical Forum 6 07-22-2006 06:04 PM
Fog Light Relay General Jackson TJ Wrangler Technical Forum 8 03-16-2006 11:57 PM
fog light relay ?'s JeepMud02 TJ Wrangler Technical Forum 17 11-21-2003 06:38 PM
