Fog Light Circuit - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Fog Light Circuit
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 12-18-2014, 09:53 PM   #1
Andythetechie
Fog Light Circuit
I installed a new bumper with LED lights in it. I wired the LEDs into the wiring for the fog lights since they are not in the new bumper. A few nights ago I noticed that even with the jeep turned off the LEDs had a slight glow to them like they were getting minimal power. They would turn on as they should so it took a while to notice the low power draw that eventually killed my battery. Has anyone else come across this? How can I use the foglight wiring with LEDs without it drawing power when turned off?
Thanks!
Andythetechie is offline   Reply With Quote Quick reply to this message
Unread 12-19-2014, 06:09 AM   #2
ultrabullit
I haven't seen anything about them staying on with a dim glow, mine would flicker for about 30 seconds after turning the jeep off. Found out this was due to the CANBUS sending out test signal to the lights looking for blown bulbs, apparently it is just a small spike that has just enough power to fire an LED but not a filament bulb. The cure for my flicker was to wire a relay directly in-line with the lights. Power to the lights thru the relay and still use the factory circuitry to trigger the relay.
1998 Sahara----Traded for JKUSp
2012 JKUSp Bright White, Black Freedom Top
Work in Progress
ultrabullit is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 01:50 AM   #3
JTB488
2014 JK Wrangler
Double check all your connections. 07's don't have Canbus so that shouldn't be causing your issue.
JTB488 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:16 AM   #4
ultrabullit
Originally Posted by JTB488 View Post
07's don't have Canbus .
Did not know this, thanks for the correction.
OP- I would do like JTB recommended and check all connections especially the ground. A bad ground can cause lots of gremlins.
Work in Progress
fog light , led
