Fog light bulb size in 2011 wrangler unlimited sport? - JeepForum.com
post #1 of 19 Old 01-08-2011, 12:57 PM Thread Starter
JohnKraut
2011 JK Wrangler
Hey does anyone know the bulb size of the Fog lights in a Wrangler unlimited Sport...thanks
JohnKraut is offline
post #2 of 19 Old 01-08-2011, 01:00 PM
1222
RIP John
1222's Avatar
Why not just take it out and look? It would have been done by now.
(2011-2016)
1222 is offline
post #3 of 19 Old 01-08-2011, 01:19 PM
J_Westy
The Owner's Manual is your friend...
You can download one here for convenience:
http://www.jeep.com/en/owners/manuals/
REPLACEMENT BULBS
Interior Lights Bulb Type
Auto. Trans. Indicator Lamp. . . . . . . . . . . . . . . . . 658
Heater Control Lamps (2). . . . . . . . . . . . . . . . . . . 194
Rocker Switch Indicator Lamp
(Rear Window Defogger, and Rear Wash/Wipe). . . . **
Soundbar Dome Lamp. . . . . . . . . . . . . . . . . . . . . 912
** Bulbs only available from authorized dealer.
Exterior Lights Bulb Type
Backup Lamps (2) . . . . . . . . . . . . . . . . . . . . . . . 3157
Center High-Mounted Stop Lamp (1). . . . . . . . . L.E.D.
Fog Lamps . . . . . . . . . . . . . . . . . . . . . . . . . PSX24W
Front Park/Turn Signal Lamps (2). . . . . . . . . . . . 3157
Front Side Marker Lamps (2) . . . . . . . . . . . . . . . . 168
Headlamps (2) . . . . . . . . . . . . . . . . . . . . . . . . . . H13
Rear Stop/Tail/Turn Lamps (2) . . . . . . . . . . . . . . 3157
License Lamp . . . . . . . . . . . . . . . . . . . . . . . . . . . 194
J_Westy is offline
post #4 of 19 Old 01-08-2011, 01:40 PM
Hilldweller
2014 JK Wrangler
No, there are no pop-in upgrades for the dreaded PSX24W.
...just anticipating your next question.
Cosmetic craptastic kiddy-ride foglights. Buy a set of Cibie Oscars, Hella Micro DE, or Bosch Compact 100 if you really want a set of foglights that work.
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #5 of 19 Old 01-08-2011, 02:05 PM
1222
RIP John
1222's Avatar
Whatís wrong with the stock fog lights? I think mine work just fine.
(2011-2016)
1222 is offline
post #6 of 19 Old 01-08-2011, 02:42 PM Thread Starter
JohnKraut
2011 JK Wrangler
thanks guys, but im curious if anyone knows how to replace my headlight bulbs i have a brighter buld i want to put in but i cant reach the headlight to remove it, anyone know a way to get to the headlight?
post #7 of 19 Old 01-08-2011, 03:06 PM
J_Westy
It's in the owner's manual -- link above.
J_Westy is offline
post #8 of 19 Old 01-08-2011, 04:21 PM Thread Starter
JohnKraut
2011 JK Wrangler
thankss
post #9 of 19 Old 01-08-2011, 04:46 PM
rirrgang
Careful about brighter. If they use more current the computer may not allow them to turn on.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #10 of 19 Old 01-08-2011, 04:49 PM
Hilldweller
2014 JK Wrangler
I have brighter flashlights.
Safety fast,
post #11 of 19 Old 01-08-2011, 06:59 PM
J_Westy
Too funny... and true
J_Westy is offline
post #12 of 19 Old 01-08-2011, 08:36 PM
1222
RIP John
1222's Avatar
Wow, thatís strange. I use mine quite a bit when off roading at night and they work just fine for me.
(2011-2016)
1222 is offline
post #13 of 19 Old 01-09-2011, 05:00 AM
Hilldweller
2014 JK Wrangler
Wow, that’s strange. I use mine quite a bit when off roading at night and they work just fine for me.
You have the older version with 9145 bulbs; twice as bright. With fresh bulbs, yours are a nominal 850 lumens ---- not terrible for foglights.
The new ones are just about cosmetic in their functionality. A joke.
Safety fast,
post #14 of 19 Old 01-09-2011, 08:52 AM
jweigel
2010 JK Wrangler
Change 2010+ with 2009-
Can one acquire a set of 2009 and older factory fog lights (housing + Bulbs) and replace the poor ones in a 2010 and newer? Will connectors be the same? is wiring the same for all years?
Or did they change the wiring to match the lower output 2010+ fogs?
Thanks for any help.
jjw
ND
jweigel is offline
post #15 of 19 Old 01-09-2011, 10:58 AM
Hilldweller
2014 JK Wrangler
jjw
ND
Connections aren't the same but an older set can be jiggered in.
It's more cost effective and you'd get better results just mounting a set of Hellas on the bumper though. They work tons better.
Safety fast,
New 2011 Jeep Wrangler Unlimited Sport JohnKraut JK Wrangler Technical Forum 15 05-16-2011 12:53 PM
Should I buy a 2011 Wrangler Unlimited? JillTheThrill JK Wrangler Technical Forum 15 12-07-2010 07:32 AM
what size bulb for shift/check engine light cluster Obcean2 YJ Wrangler Technical Forum 1 02-22-2010 01:17 PM
Fog light switch bulb size geepguy99 TJ Wrangler Technical Forum 3 11-20-2009 06:46 PM
Dash light bulb size? flexsaharatj TJ Wrangler Technical Forum 3 08-05-2009 06:48 PM
