Flush Mount LED Tail lights - Page 2 - JeepForum.com
post #16 of 29 Old 01-15-2013, 05:39 AM
mikeg576
1945 CJ2A
Thanks, you can get these from www.isee-systems.com /Doug Miller is the owner of Isee systems and Advanced Vehicle Systems. You can tell him I sent you.
dougm@advancedvehiclesystems.com
45 2A 95 YJ,
Jankel Tactical Systems Northeast
mikeg576 is offline
post #17 of 29 Old 01-16-2013, 07:22 PM Thread Starter
jk13crush
nice work mike and thanks for the info. i thought it was going to be easier to do like the yj/tjs
jk13crush is offline
post #18 of 29 Old 01-16-2013, 08:36 PM
mikeg576
1945 CJ2A
Thanks. If you look at my build early on you'll see my idea changes a bit from how I was mounting them. Thanks
45 2A 95 YJ,
mikeg576 is offline
post #19 of 29 Old 01-17-2013, 07:34 AM
kappaknight
Originally Posted by mikeg576 View Post
The problem I had was the angle and curve of the Jk corners don't really let flush mounting lights to be done easy.
I used AEV builders corners.
Question about these lights - do the military ones not have backup lights built in? I wonder why they don't offer a version with the backup lights built in.
kappaknight is offline
post #20 of 29 Old 01-17-2013, 02:21 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Because its a military lamp
My builds:
and
or follow us on
spyder6 is offline
post #21 of 29 Old 01-28-2013, 09:13 AM
mikeg576
1945 CJ2A
Military tail lamps do not have standard back up lamps. There is a small blackout light under the small lowest hood on the body. With NVG's it is visible. No MilSpec lamp is made with civilian backup lamps.
45 2A 95 YJ,
mikeg576 is offline
post #22 of 29 Old 07-13-2013, 07:49 AM
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
I know this is an old thread but anyone doing a search might find this useful. An affordable conversion!
http://www.jeepforum.com/forum/f43/r...n-kit-1548195/
Jeff
sales@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline
post #23 of 29 Old 07-13-2013, 09:50 AM
mikeg576
1945 CJ2A
Just a updat, www.isee-systems.net is Doug's revised site.
Those rockridge lights you're showing are nice. They serve the purpose. But my only problem is they look like every other LED tail lamp out there and don't add any sort of protection otherwise. Not trying to bust your balls. I'm just saying when I see a "new product" I like to see its new and not just a different shade of black.
My lamps are not a product as much as the Rockridge. What I did would e very expensive but that's why I built them. I wanted something totally functional and different.
45 2A 95 YJ,
mikeg576 is offline
post #24 of 29 Old 07-13-2013, 09:56 AM
Rockridge4WD
Vendor
2010 JK Wrangler
Yes sir. These are a simple conversion for the guy that doesn't want to replace his oem stock light after he rips it off on the trail. No balls busted.
post #25 of 29 Old 07-13-2013, 09:59 AM
mikeg576
1945 CJ2A
Awesome. So is there any extra cutting on the body? I had to make a much larger hole for mine which kinda sucks. I see you have nutcerts but was that all?
45 2A 95 YJ,
mikeg576 is offline
post #26 of 29 Old 07-13-2013, 10:09 AM
Rockridge4WD
Vendor
2010 JK Wrangler
Just the raised ears that stick out and then drill 6 holes.
post #27 of 29 Old 07-13-2013, 12:30 PM
TrailDuty
2011 JK Wrangler
www.jeepforum.com/forum/f43/rockridge4wd-introduces-new-jeep-wrangler-jk-led-tail-light-conversion-kit-1548195/
Jeff
That's a cool conversion. Would sure save my taillights from being ripped off. Not too expensive either.My only concern is how bright are the reverse lights? They look kind of small.
TrailDuty is offline
post #28 of 29 Old 07-13-2013, 04:39 PM
thunderball
Jeff
Being that leds are directional...these facing out a few degrees isn't a problem? Nice clean setup for sure.
thunderball is offline
post #29 of 29 Old 07-15-2013, 10:45 AM
Rockridge4WD
Vendor
2010 JK Wrangler
Don't let the size fool you. These little back up lights back a punch. 200 Lumens a piece. They are brighter then any stock back up light. These lights are also good for rock lights, under the hood lights, tool box light etc.
flush mount lights , jk
