Flat Towing a CJ-7 with my '12 JKUR? - Page 2 - JeepForum.com
post #16 of 39 Old 06-26-2013, 02:46 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by rayder1 View Post
There is none such a thing as a "Top Cop" unless he or she is the Chief of Police, then it may be okay to say that.
LOL we SOOOOO agree on that. I MEANT top cop exactly as you just defined.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #17 of 39 Old 06-26-2013, 02:53 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by smbundy13 View Post
um... so, now my question is do yall think a JKUR would be able to handle a 16ft flatbed trailer? I dont have a trailer brake hook up in my JK...
I am more concerned with safety than the letter of the law... I dont expect to get ticketed either way... just want to do damage to either vehicle..
so, what do yall think? safe/smart or unsafe/dumb to flat-tow my CJ 550 miles behing by JKUR?
thanks for the plethora of info on GVWR and all that other stuff..
I would have no issues flat towing a Texas tagged CJ behind a Texas tagged JKUR - even without brakes. Just (so that you don't get surprised and thus emotionally confrontational if pulled over) keep in mind... there may be cause for roadway discussion.
lol
Make sure all your lights work etc so there is NO OTHER REASON to pull you over and you'll be okay. I would hesitate to pull it on a 16 footer - thats three times longer than the JK. Jus kidding but close - my reasoning there is that flat towing is very little tongue weight (just the weight of the bar set) while a trailer has to have at least 10% of the trailers weight on the tongue to handle well.
post #18 of 39 Old 06-26-2013, 02:58 PM Thread Starter
smbundy13
1980 CJ7
Originally Posted by jwmbishop View Post
I would have no issues flat towing a CJ behind a JKUR. Just (so that you don't get surprised and thus emotionally confrontational if pulled over) keep in mind....
lol
Make sure all your lights work etc so there is NO OTHER REASON to pull you over and you'll be okay. I would hesitate to pull it on a 16 footer - thats three times longer than the JK (jus kidding but close). But my reasoning there is that flat towing is very little tongue weight (just the weight of the bar set) while a trailer has to have at least 10% of the trailers weight on the tongue to handle well.
thanks for the info
ok, well if I flat-tow it, I will get a set of the magnetic lights for tail lights.. since the CJ isnt wired to do the trailer light action.
smbundy13 is offline
post #19 of 39 Old 06-26-2013, 05:55 PM
rayder1
Yep. You "should" have a breakaway brake set up if the dinghy detatched from hitch it stops itself. That's minimum
A 16 foot flatbed will raise the weight quite a bit and may have hookups you don't have.
rayder1 is offline
post #20 of 39 Old 06-27-2013, 08:28 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Doesn't that happen automatically when the tow bar becomes a vault pole?
post #21 of 39 Old 06-29-2013, 01:40 AM
rayder1
LOL.....yes. But the guy with the ticket book likes to see the little chain or wire for the disconnect brake.
rayder1 is offline
post #22 of 39 Old 07-01-2013, 08:58 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
And here in Tx that guy also likes to see the safety chains crossed. Most WILL pull over if they see em parallel - but usually just to politely warn.
post #23 of 39 Old 07-13-2013, 09:29 PM
Graves
I'm in the process of flat towing my yj with my jku from NC to FL- ~900 miles. I've passed/been passed by quite a few police officers without a second glance. Use magnetic trailer lights, keep it 5 below, leave plenty of space, and don't do anything stupid.
Graves is offline
post #24 of 39 Old 12-12-2013, 01:11 PM Thread Starter
smbundy13
1980 CJ7
lol
ok, I am going to be flat-towing the Jeep from TX to AL. my JK is tagged in alabama so it will be a TX tagged CJ behind an AL tagged JK... I dont think that will be an issue... just need to show the title etc.. but, my plan is to cruise at 65...
how did the trip go? did you remove the driveshafts in the YJ? any advice?
thanks.
post #25 of 39 Old 12-13-2013, 09:44 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
As long as you have the basics - (LIGHTS and safty chains) probably no problem. As good friend (hiway patrolman) gave me some of HIS insight when I brought up this discussion - a motor home dingy towing a Jeep - he tends to believe they do it all the time - enough that he makes sure they have brakes, breakaway, chains lights etc up to code. Usually just warning unless its a gross violation.
When he sees a truck or etc flat towing he sees the likelihood that its a one time thing so as long as it has the basics (lights and chains) and appears safe enough to get him down the road he doesn't give it a second thought...
post #26 of 39 Old 12-13-2013, 10:25 AM
Graves
thanks.
Trip went fine. Stay on the interstate and avoid curvy roads. Plan your fuel stops b/c you're more likely to get in trouble making tight turns and you can't reverse. Like I said earlier, had many LEO's pass without giving a second look. As for the YJ, I didn't remove anything. Just followed the manuals instructions for flat towing. Transmission in gear and transfer case neutral. Key in the position to unlock the steering wheel but keeping electrics off.
Oh! And ignore the annoyed looks by people in a hurry. Your safety is more important than their time.
94 YJ & 13 JK
Graves is offline
post #27 of 39 Old 12-13-2013, 02:32 PM Thread Starter
smbundy13
1980 CJ7
awesome! thanks for the info.. yeah my trip is about 550 miles total.. about 500 of that is on I-20.. so that biggest thing will be fuel stops and getting to and from the interstate...
thanks again for the info.
post #28 of 39 Old 12-13-2013, 02:33 PM Thread Starter
smbundy13
1980 CJ7
thanks for the info...
post #29 of 39 Old 12-14-2013, 02:44 PM
zjilla
Just do it. Yolo
Sent from my GT-N7000 using JeepForum
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #30 of 39 Old 12-24-2013, 04:01 PM Thread Starter
smbundy13
1980 CJ7
Well I am going to have to put my CJ on a trailer back to bama. The tires are about 15 years old and I am pretty sure they would self destruct at highway speeds. I will post some pictures of my jeep later on.
DD - 2013 Ford F150 Platinum Eco-Boost
1980 CJ-7 rehab in progress
