Flat Towing - JeepForum.com
post #1 of 27 Old 10-17-2013, 07:59 PM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
Flat Towing
I flat towed the JK for the first time today, it was only about 180 miles, wow was that ***** stinking like it was "smoking" something,
The t-case and manual transmission were all in neutral, the parking brake was off and nothing was touching the pedal, the wheel could turn freely. What the heck is it? The stink lingered for hours too. Seemed to drive ok Fterwards.
'15 Expedition EL, '12 Outback,'07 JK, '06 Mustang GT, '05 PowerWagon,'05 Freestar, '02 Yamaha
NIUPonyBoy is offline
post #2 of 27 Old 10-18-2013, 07:24 AM
Kuntryboy816
Kuntryboy816's Avatar
Interesting.... I'd start with checking all of your fluids first...Transmission and transfer case. Did you disconnect your driveshafts when you towed it?
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is online now
post #3 of 27 Old 10-18-2013, 07:30 AM
jeepman788
Check it out but I think the trans should be in a forward gear - supplies (pumps) oil to output bearing.
And T-Case in neutral.
jeepman788 is offline
post #4 of 27 Old 10-18-2013, 11:10 AM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
Fluids looked fine, but the manual Trans should be in a gear? 1-6? I was told everything in neutral. And no the shafts were still attached with the t-case in neutral.
post #5 of 27 Old 10-20-2013, 07:29 AM
the_weirdo
the_weirdo's Avatar
With a manual tranny you want the transmission in gear (with auto, you want it in park). You do it this way to keep the tranny output from spinning without lubrication which can toast the bearings. Placing the tranny in gear keeps the tranny shaft from spinning. You can leave the tcase in neutral because the oil pump is on the output shaft of the tranny and spins whenever the rear driveshaft spins so the bearings get lubricated.
the_weirdo is offline
post #6 of 27 Old 10-20-2013, 07:39 AM
ncb
Owners manual- when it doubt, whip it out.
ncb is offline
post #7 of 27 Old 10-20-2013, 10:05 AM
Kuntryboy816
The last part of that quote has caused many a problem at colleges, parties, bars...........
post #8 of 27 Old 10-20-2013, 10:34 AM
TOK
I have never flat towed, and would prefer to get a car trailer, but was really surprised by the instructions. If you have a manual trans vehicle, are you just supposed to leave it in 6th gear? Does the gear not even matter since the transfer case is in neutral?
TOK is offline
post #9 of 27 Old 10-20-2013, 10:47 AM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
^ what you said.
Thanks all!
post #10 of 27 Old 10-20-2013, 01:52 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
You got the front of your transfer case REAL hot. Find some sand or gravel and make sure it works fine in 4WD.
The transfer case is the split - just like jacking up an open diff and turning one tire turns the other side (backwards) if the yoke cant turn - The input of the transfer must be held stationary for the oil in the front half of the transfer case to flow properly. This requires transfer N, Transmission P (or 3rd on standard).
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #11 of 27 Old 10-20-2013, 01:57 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
In Gear or Park. Gears matters to hold transfer input shaft stationary.
post #12 of 27 Old 10-20-2013, 02:16 PM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
Any particular reason for 3rd?
post #13 of 27 Old 10-20-2013, 05:12 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Just the gear I pick - shifter fwd out way and easy gate to find. using first to check transfer case could still lurch the vehicle if not careful (like rushing to hitch in rain) - third will stall without hitting the tow vehicle!
post #14 of 27 Old 10-21-2013, 06:33 AM
dav5942
dav5942's Avatar
Have towed jeeps for over 1 million miles, XJs, TJs, JKs. Much easier than a trailer, takes less than 5 minutes to hook them up. Headed back to Alaska next summer for another 15k miles.
Rubicon-a point of which any action taken commits the person taking it to a further course of action that cannot be avoided!
dav5942 is offline
post #15 of 27 Old 10-21-2013, 08:59 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
My 71 year old mother hitches, unhitches and tows behind her RV all by herself all over the country.
