Flash and It Feels Like a New Engine - Immediate Performance Increase - JeepForum.com
post #1 of 39 Old 02-16-2009, 04:46 PM Thread Starter
rac-jeep
Have had my 4 door JK for over a year and a half. The Engine has always felt "under-powered" to me. I thought this was a combination of me moving up from a two door TJ and the "minivan" engine replacing my beloved straight six. There was always a noticable dip in power in about a third of the way into the acceleration curve. On humid days it was even worse.
Today I finally took my Jeep in for a first visit to the Professionals. In addition to several other minor issues, I mentioned the dip in power to the Service Rep.
They did a reflash on one of the Modules and I can't believe the difference in performance. It seriously feels like a completely different machine. Noticably more horse power thru the entire acceleration curve. Can't believe I drove this for 20 months without knowing there was a remedy.
rac-jeep is offline
post #2 of 39 Old 02-16-2009, 06:29 PM
redrockin7
By professionals you mean the dealer?
Interesting observation... I'll keep it in mind when/if mine begins to feel sluggish. I mean, it feels slow compared to my previous vehicles (350z, etc.) but for a big heavy JEEP it moves fine up to 80mph and almost got me a speeding ticket the other day. So... it can't be that slow...
However, I will confirm that a flash will definitely help out in some circumstances. I had a bunch of "bolt-ons" on my 350 and ran it lean for a while. Reflashed the ECU and had the curve set-up to "match" the modifications and picked up a good 15hp and 16tq at the wheels... Wouldn't expect this same kind of gains flashing a stock vehicle, but hey it can't hurt I guess?
redrockin7 is offline
post #3 of 39 Old 02-16-2009, 07:30 PM
OffTheGrid
Can you provide more specifics, like which module and why they flashed it?
OffTheGrid is offline
post #4 of 39 Old 02-16-2009, 07:41 PM Thread Starter
rac-jeep
Yes. "Professionals" = Dealer Service
As far as the specifics. Looking at my invoice here is all I see (I will ask for details)
181906c1,.4 hour,fc-zz
85410000,.4 hour perform drive test-ck. fuel pressure,ck. for codes,star scan tested,no dtcs-
no freeze frame data-test drove ---perform tsb---flash pcm---
That is all I got right now!
rac-jeep is offline
post #5 of 39 Old 02-16-2009, 08:29 PM
ChicagoGuy
Team XBOX
ChicagoGuy's Avatar
So not to call you out or anything - maybe I misread - but could it be that you've had the Jeep for 20 months and just brought it in for your first service be the reason it now runs decent?
(If you do your own maint and just brought it in because it was driving fubar, I retract my comment)
- Bill (formerly VetteDriver)
ChicagoGuy is offline
post #6 of 39 Old 02-16-2009, 08:40 PM Thread Starter
rac-jeep
Not certain I understand. Not feeling called out!
Yes. First time I've brought the Jeep in for Dealer Service. Only thing that really made me go in for service was a broken windshield and a recall that I'd never addressed. Otherwise I do tend to do a bit of self-service.
I was completely ignorant of the Engine Performance issue. I just sort of assumed that it was my expectations being too high. I really didn't know that it was a real "issue" - not really fubar.
Just really delighted with the results and wanted to share my experience.
rac-jeep is offline
post #7 of 39 Old 02-16-2009, 08:46 PM
ChicagoGuy
Team XBOX
ChicagoGuy's Avatar
Gotcha. Cool to know.
post #8 of 39 Old 02-17-2009, 04:06 AM
y2k8jeep
I asked a friend who works for a dealer about this. He indeed said there was a TSB and that re-flashing was worth another 15 hp or so. He then showed me a trail behind the dealer and told me if I were to follow the trail I'd find a leprechaun who would gladly give me some gold coins as he had a pot full of them.....my buddy said I might use them to help pay for a hemi swap if I so desired....
y2k8jeep is offline
post #9 of 39 Old 02-17-2009, 07:59 AM
Dryfter
What dealer you going to? I could use a pot of gold...
Dryfter is offline
post #10 of 39 Old 02-17-2009, 09:04 AM Thread Starter
rac-jeep
Thanks for the helpful and insightful post. It was every bit as constructive as I am sure you intended.
rac-jeep is offline
post #11 of 39 Old 02-17-2009, 09:08 AM Thread Starter
rac-jeep
Now...
...for anyone who would like the information about the Flash performed on my Jeep yesterday.
Just got off the phone with Brook, the Service Advisor at my local dealer. He said that the Flash is referenced by the TSB Number(s). This one has two TSB Numbers which reference the same Flash.
They are:
21-018-08
08-023-07
I smiled the entire commute to work this morning. Smooth and even performance through all gears.
rac-jeep is offline
post #12 of 39 Old 02-17-2009, 09:16 AM Thread Starter
rac-jeep
I just looked up those TSBs and don't see exactly what they seem to have to do with my symptoms/fix, but it did the job.
rac-jeep is offline
post #13 of 39 Old 02-17-2009, 09:19 AM
SaharaBlackNo1
Originally Posted by rac-jeep View Post
Now...
They are:
21-018-08
08-023-07
NUMBER: 21-018-08 REV. A
GROUP: Transmission
DATE: September 17, 2008
SUBJECT:
Flash: Diagnostic Trouble Code DTC P0740 Or P1798 And Automatic Transmission Shift Improvements 1-2 Or 2-3 Cold Shift Improvements
MODEL:
2007 - 2008 (JK) Wrangler
NOTE: This Bulletin applies to LX/LE models equipped with a 42 RLE transmission (Sales Code DGV) built before April 28, 2008 (0428XXMDH). This Bulletin applies to all 2008 KA/KK/HB/DR and 2007 - 2008 **JK**/ND vehicles equipped with a 42 RLE transmission (Sales Code DGV).
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM).
SYMPTOM/CONDITION:
The software contains the following improvements:
2008 LX 3.5L 1-2 Shift Improvements
Cold (Transmission Fluid below 80 F) 2-3 Shift Improvements
Some customers may experience one or more of the concerns as follows:
A MIL illumination for P0740 - Torque Converter Clutch Circuit/Open
A DTC set active or stored for P1798 - Transmission Fluid Deteriorated
Do not confuse this condition for an Oil Change Monitor alert due to the Oil Change Monitor not being reset following an oil change.
That flash most likely explains your JK waking up.
AEV: Hood, Skidplate & Bumper, jackstand and Badging Expedition One Rear Bumper,RE 4.5" Long Arm Kit,5.13s, Black Riddler Diff Covers, Hypertech Airaid CAI, PIAA 540s w/flush mounted switch, Flowmaster 40, 325/60/22 BFGs and the list goes on...
SaharaBlackNo1 is offline
post #14 of 39 Old 02-17-2009, 09:21 AM
SaharaBlackNo1
And the second one is:
NUMBER: 08-023-07
GROUP: Electrical
DATE: October 06, 2007
SUBJECT:
Long Crank Time Due To Possible Contact Of Camshaft Sensor To Camshaft Gear
OVERVIEW:
This bulletin involves the replacement of the engine camshaft sensor.
MODELS:
2007 (JK) Wrangler
SYMPTOM/CONDITION:
The customer may experience one of the following conditions:
a). Long engine crank time.
b). Two engine start attempts prior to engine starting.
c). Due to the “TIP Start Feature” on automatic transmission equipped vehicles, once the ignition key / switch has been released from the “START” position, the starter may stay engaged for up to 10 seconds while the engine attempts to start.
The above conditions may be due to the position of the camshaft sensor to the camshaft gear. The sensor spacer gasket may have come loose during engine assembly and caused the camshaft sensor to be adjusted too close or in contact with the camshaft gear.
post #15 of 39 Old 02-17-2009, 09:24 AM Thread Starter
rac-jeep
I saw that, but but was confused because I have a 6 Speed Manual Transmission and this seems targeted at an Auto Transmission issue (unless I am reading it incorrectly)
rac-jeep is offline
Performance increase 92 YJ 2.5 4cyl sdelliott31 YJ Wrangler Technical Forum 35 02-26-2009 03:34 PM
Performance chips increase mileage? heavymetal99 TJ Wrangler Technical Forum 14 02-11-2008 09:38 PM
Performance chip increase mileage? heavymetal99 TJ Wrangler Technical Forum 7 02-04-2008 11:11 AM
Dealership question and bolt on performance increase? CoriolisSTORM TJ Wrangler Technical Forum 8 04-25-2005 09:00 AM
Performance increase Whybu1 TJ Wrangler Technical Forum 10 08-31-2002 05:06 PM
