Fixes for Tire rubbing front Sway bar - JeepForum.com
post #1 of 17 Old 06-17-2013, 01:31 PM Thread Starter
cj7guy
I have slightly upsized tires on my JKU, and they rub the sway bar at full lock.
I wouldn't normally care, but the JKU turning radius is already pretty wide. I refuse to lift to fix this because I can already clear the tires I have.
I was considering removing the sway bar altogether, but I do drive it on the highway a good bit so I'd prefer not to lose the handling advantages of the sway bar.
Does anyone make a slimmer profile sway bar? This stock one sticks out further than necessary into the wheel well.
07 JKU - 6spd - LSD rear
cj7guy is offline
post #2 of 17 Old 06-17-2013, 01:37 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
What size tires? Perhaps you need to move the wheel further out if still running stock rims?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 17 Old 06-17-2013, 01:41 PM Thread Starter
cj7guy
I am on stock rims, I think the tires are 285/70 17s.
I'm hesitant to go wider because I like to run doorless and I don't want rocks and other debris flying up. Right now the fenders keep the crap from flying. Also, wider fenders are out of the question.
I mean, the sway bar is the offending item...I want to move/trim/modify it if at all possible.
I may end up just removing it or getting a local shop to fab a new one.
cj7guy is offline
post #4 of 17 Old 06-17-2013, 01:49 PM
ncb
Wheels with 4.5" of back spacing or 1.5" spacers will fix it. I had the same size tires with 4.5" back spaced wheels and they were even with the fenders.
ncb is offline
post #5 of 17 Old 06-17-2013, 01:54 PM
Noxian
2011 JK Wrangler
You could add some washer to your steering stops, but you will end up with the same radius the only solution is adding more back spacing otherwise.
Noxian is offline
post #6 of 17 Old 06-17-2013, 02:03 PM
brianjw
So you're saying your tires rub in one sentence, then saying that they clear in the next sentence. If they rub, they don't really clear.
You need either small wheel spacers or wheels that are the proper size and backspace. AEV wheels are probably the best fit for what you want without being really wide.
You could look into the teraflex dual rate sway bar, currie anti-rock etc and see it they may offer any more clearance. It would be minimal if any. Personally Id sell the stock wheels and buy AEV "jk specific" wheels, leave the rest alone.
brianjw is offline
post #7 of 17 Old 06-17-2013, 02:07 PM
ncb
OP is saying he can clear the tires height wise in the "next" sentence.
ncb is offline
post #8 of 17 Old 06-17-2013, 02:10 PM Thread Starter
cj7guy
You know what I mean....they clear the body, the frame, and every other component....except the sway bar. Basically, I have no valid reason to raise my COG.
Thanks for the input, maybe the AEVs won't make me wide enough for the tires to throw too much debris up at me.
I really like my current setup and was hoping there was a fix for this sway bar issue that wouldn't require me to change anything except the sway bar. Looks like I'll keep rubbing for a short while until I decide which fix will work best.
If anyone has modified the sway bar setup to get out of the way of the tires, I'd love to hear from you.
Has anyone just removed it altogether and can report on highway manners?
cj7guy is offline
post #9 of 17 Old 06-17-2013, 02:35 PM
mello
Removing front sway bar would give you scary road manners. This would specially hold true on high speed maneuvers and curvy roads.
mello is offline
post #10 of 17 Old 06-20-2013, 01:16 AM Thread Starter
cj7guy
I removed the front sway bar from the JKU and it drives noticeably differently in the corners. It's not scary though, I took some twistys at 60-70 and it was a little twitchier but still manageable.
cj7guy is offline
post #11 of 17 Old 06-20-2013, 02:09 AM
hrd2plz
Not a safe idea...
hrd2plz is offline
post #12 of 17 Old 06-20-2013, 08:38 AM
GauchoMark
2011 JK Wrangler
Normal driving without a front sway bar isn't that big of a deal - I had a previous lifted 4x4 vehicle that I drove without a sway bar quite a bit (because teh links kept breaking). Emergency maneuvers without a sway bar is scary. I wouldn't recommend it for a street vehicle.
GauchoMark is offline
post #13 of 17 Old 06-20-2013, 09:36 AM
sieg
[QUOTE=cj7guy;15572469]I have slightly upsized tires on my JKU, and they rub the sway bar at full lock.
QUOTE]
How far from the stops are you when it rubs? It's probably at full lock anyway, therefore not restricting your turning radius. Let it rub, what will it hurt? My tires rub the control arms at full lock, it doesn't seen to hurt anything but the paint on the control arms. You are going slow and not very far at full lock anyway.
sieg is offline
post #14 of 17 Old 06-20-2013, 04:36 PM
SubAtomicGenius
2011 JK Wrangler
Incorrect backspacing using stock wheels is the offending item. Big tires = bigger clearance required, and yes, they'll stick outside your flares then.
Personally, I wouldn't run on the street without swaybar links. First I'd go with proper backspace wheels, perhaps a Currie antirock setup (?), or spacers (in that order!).
SubAtomicGenius is offline
post #15 of 17 Old 06-20-2013, 06:08 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
For what it is worth, ADDCO makes larger diameter sway bars for the front and rear. I went bigger in my tires and had the same rubbing issue on the sway bar. I ordered both ADDCO's from Kolak and now I do not have the rubbing issue any more in the front. I am not saying that you would get the same clearance as they may make the bars a little different each time, not sure. I ordered the ADDCO's to try and help in the handling department, but did not see anything of value in that department for the price. Here are some pic's of the 2 bars together, the ADDCO is the black one on the bottom and the stock is on the top.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
