First oil change - JeepForum.com
post #1 of 19 Old 11-09-2012, 11:46 AM Thread Starter
jharkey
First oil change
My change oil notification came on at 3500 miles. Should I go ahead and change it?
jharkey is offline
post #2 of 19 Old 11-09-2012, 11:48 AM
janders82
2010 JK Wrangler
yes
janders82 is offline
post #3 of 19 Old 11-09-2012, 12:28 PM
smartbutlazy374
2011 JK Wrangler
Do it. If you do it yourself, make sure you get some quality oil with a good filter.
"This is why you do all your mods before you get a wife." - WhiteOut
"I have come to the conclusion that the wave is NOT a Jeep thing- it is a WHEELER thing." -N2rock
smartbutlazy374 is offline
post #4 of 19 Old 11-09-2012, 01:39 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Yes - check with your dealer to see if they have a prepaid package - I got 12 for 150.00. That's less than I can buy the filter for...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #5 of 19 Old 11-09-2012, 01:56 PM
Jiblet
And don't forget to reset it.
Jiblet is offline
post #6 of 19 Old 11-09-2012, 03:29 PM
pentastarguy
2015 JK Wrangler
yes, and forget the dealer, change it yourself so you know it i done right. don't forget to save the receipt.
pentastarguy is offline
post #7 of 19 Old 11-09-2012, 05:16 PM
rirrgang
Then switch to Syn 5w-20 Mobil 1 and an extended length wix filter 51516 or one of the following. Change at every 10k. Save your receipts.
Extended Length
Mobil 1 - M1-209
K&N - HP2009
Pure One - PL20195
Amsoil - EAO34
Wix - 51516
AC Delco - PF56
Motorcraft - FL400
Fram - PH3600
Purolator - L20195
Napa - 1516
Bosch 3422
-Rick
07 Sahara Unlimited
rirrgang is offline
post #8 of 19 Old 11-09-2012, 08:42 PM Thread Starter
jharkey
Thanks
jharkey is offline
post #9 of 19 Old 11-09-2012, 08:49 PM
nwpipelayerxj
1997 XJ Cherokee
That Mobil 1 extended synthetic is good stuff I run it in everything
nwpipelayerxj is offline
post #10 of 19 Old 11-09-2012, 08:57 PM
starfish
Extended Length
Mobil 1 - M1-209
K&N - HP2009
Pure One - PL20195
Amsoil - EAO34
Wix - 51516
AC Delco - PF56
Motorcraft - FL400
Fram - PH3600
Purolator - L20195
Napa - 1516
Bosch 3422
Is 10K the normal interval? Or is that when using full synth? I saw 3500 for the first change in the user's manual, but didn't really see an interval after that.
starfish is offline
post #11 of 19 Old 11-09-2012, 09:19 PM
nwpipelayerxj
1997 XJ Cherokee
10k is for the mobil1 extended synthetic and you have to get the filter that's is good for the same amount. Otherwise yeah 3-4k changes
post #12 of 19 Old 11-10-2012, 08:08 AM
rirrgang
There is no reason to waste your money at 3-4k oil changes. Modern engines and unleaded gas paved the way to longer change intervals, even with dino oil.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #13 of 19 Old 11-10-2012, 08:55 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
So if I pre-pay 150 for 12 changes/3 years (12.50 per change) - and only drive 10,000 per year but use all 4 at 2500 miles each I am wasting my money?
Good point so I will only do 2 changes per year at 49.95 each for a three year cost of - 299.70. (or do it myself at 23.79 for the oil and 7.00 for the filter for 30.00 per change - or 180 per year - plus my TIME which is now worth negative 30.00 under this plan) That way I am not wasting my money even though I am spending more. Are you by any chance a Democratic President?
And we all know that NO TRAIL DUST, ROAD DUST OR ATMOSPHERIC\ACIDIC MOISTURE EVER EVER GETS IN THE CRANKCASE AS THE TEMP CHANGES AND DRAWS OR EXPELS AIR VOLUME.
post #14 of 19 Old 11-10-2012, 09:01 AM
starfish
Yeah, I know. Old habits die hard. I've religiously changed my 06 Ram 1500 Hemi, using dino, at every 3-4 k. It still comes out as clean as it goes in, after six years. Throwing money away, I know, but I don't put a lot of miles on it. Only about 8k a year, so really one or two oil changes a year, done by me, is not much of an expense.
starfish is offline
post #15 of 19 Old 11-10-2012, 09:36 AM
nwpipelayerxj
1997 XJ Cherokee
Yeah two a year at 4-5k isn't that big of a deal and still insures it is very clean
