First hard rain - JeepForum.com
post #1 of 25 Old 11-26-2013, 02:32 PM Thread Starter
sccpdc
2014 JK Wrangler
First hard rain
We had our first hard rain today, checked my 2014 JK sport. I seem to have a leak around the soft top header seal, can't get to it just yet still raining, any one have this problem?
Florida Jeep
sccpdc is offline
post #2 of 25 Old 11-26-2013, 08:16 PM
Gumby1
2014 JK Wrangler
Yup, had my 2014 for 2 days and went out to a soaked interior. Was not impressed.
Gumby1 is offline
post #3 of 25 Old 11-26-2013, 11:13 PM
TheGoodStuff
2010 JK Wrangler
It's not a jeep unless it leaks or squeaks ;wink ;wink
TheGoodStuff is offline
post #4 of 25 Old 11-27-2013, 12:41 AM
AveCat
Take it to the dealer! My 2012 is fine.
2012 Wrangler JK 3.6 W/ 6 Speed bought 2/15/13
2.5" Rock Krawler Lift - Bilstein 5100s - 315/70/17 Duratracs - AEV Control Arms
TruckLite - Rigid
AveCat is offline
post #5 of 25 Old 11-27-2013, 09:22 AM
ROCKR8R
Common problem. The dealer will fix under warranty. Take pictures
-Dan
ROCKR8R is offline
post #6 of 25 Old 11-27-2013, 09:25 AM
cyberpyrot
yup just remove the carpet and bedline it
cyberpyrot is offline
post #7 of 25 Old 11-27-2013, 03:47 PM
muddr1
I was having water issues too. The last time I had my tops off, I applied some silicone spray to a rag and wiped down all the rubber seals on the tops and where they sit on the jeep. We had heavy rain today and the floor was dry as can be. Cheap fix and worth a try.
If we knew what we were doing it woulnt be called research
Albert Einstein
There are no rules here, were trying to accomplish something.
Thomas Edison Keep Calm,Chive On
muddr1 is offline
post #8 of 25 Old 11-27-2013, 04:11 PM
MyJKU14
2014 JK Wrangler
Is this a problem with the soft tops or for the hard tops as well?
'14 JKU
'05 LJ Rubicon (husband's)
Colorado Jeep Club #281
Past Jeeps: '02 WJ Overland, '02 WJ Limited, '08 KK Sport
MyJKU14 is offline
post #9 of 25 Old 11-27-2013, 05:09 PM
muddr1
I have read mostly hard tops....
Albert Einstein
muddr1 is offline
post #10 of 25 Old 11-29-2013, 07:38 PM
73azbronco
My 2dr just back from dealer after having an inch of water on passenger floor, so much the rear passenger footwell was wet. They replaced the passenger door seal and one roof seal. But when I go to pick it up, floor is still soaked, I was told "let it dry out" after I overheard mechanic say to tech rep "it's to hard to pull the carpet". YGBFSM. I have a fan blowing on it overnight. I've been impressed with dealer to this point, I hope this is a rare occurrence.
73azbronco is offline
post #11 of 25 Old 11-30-2013, 05:56 AM
TheBoss
Take the carpet out and let it hang dry. It will dry much faster allowing you to pull the drain plug and blot up any remaining water on the floorboard. It is not hard to do at all they are made to be removable.
TheBoss is offline
post #12 of 25 Old 11-30-2013, 09:40 AM
73azbronco
That's the issue, that's what I asked the dealer to do and they said and I quote, that's to hard to do. So no, I'm not pulling carpet, if it's not dry Monday it's back to dealer.
post #13 of 25 Old 11-30-2013, 12:03 PM Thread Starter
sccpdc
2014 JK Wrangler
It really is not hard to take it out, there are slits around where the seat is bolted to the floor. There is one plastic wing nut under the seat and three at the front top of the carpet. The carpet is in four sections, the back bed, the back passenger floor and the front drivers side, the front passenger side. I did not remove the back bed it was not wet. I started with the back passenger on the driver side. Worker the carpet free from around where the seat is bolted down. Make shure the wing nut has been removed. Work the carpet from underneath pushing up. Then pull out from under seat. Do this on both sides. Back passenger carpet comes out on one piece. Then work on the front. Set out in sun during day in house at night. After two days mine was dry. I still have it out so I can check the top for the leek just in case it was my fault for not putting the top back on properly.
Florida Jeep
sccpdc is offline
post #14 of 25 Old 11-30-2013, 03:20 PM Thread Starter
sccpdc
2014 JK Wrangler
Try this.
Haven't seen a negative review yet. Gummi Pflege - Weather Stripping Conditioner | einszett Car Care Products
I just ordered some from amazon today.
Florida Jeep
sccpdc is offline
post #15 of 25 Old 11-30-2013, 08:14 PM
pentastarguy
2015 JK Wrangler
i understand your frustration with the dealer, but do it yourself so don't get mold.
pentastarguy is offline
