Firewall access? - JeepForum.com
post #1 of 4 Old 04-27-2007, 11:25 AM Thread Starter
billycj7
Firewall access?
Who has found a way through the firewall on a 6-speed?
billycj7 is offline
post #2 of 4 Old 04-27-2007, 11:39 AM
DTarlo
just drill a hole and put a grommet in, easy as pie on a jeep
DTarlo is offline
post #3 of 4 Old 04-27-2007, 02:21 PM
Squint
Squint's Avatar
Unless there is a difference between auto/manual, there is a large grommet directly under the battery. Use a coat hanger or automotive radio antenna, tape the wire to it and then fish them through the grommet. Be careful not to use anything sharp, you don't want to harm the existing wires.
If you decide to drill a hole, don't pick a place to low on the firewall, unless you don't intend to ford any water.
Squint is offline
post #4 of 4 Old 04-27-2007, 03:28 PM
tomc121
tomc121
tomc121's Avatar
there is a tread on this on next page
tomc121 is offline
Trans access cover?! 1993redjeepyj YJ Wrangler Technical Forum 24 03-18-2009 06:48 AM
Firewall Access! aquaman448 JK Wrangler Technical Forum 9 06-21-2008 10:49 PM
Halftop access? JasonJW TJ Wrangler Technical Forum 3 03-28-2008 03:47 PM
backseat access? nsrstevens80 JK Wrangler Technical Forum 6 12-26-2006 09:53 AM
i got access to a 350 and a turbo 350 for next to nothing YoungJeeper YJ Wrangler Technical Forum 5 06-25-2004 10:59 PM
