find axle ratio - JeepForum.com
post #1 of 4 Old 04-04-2009, 10:45 AM Thread Starter
virtual_mage
2009 JK Wrangler
find axle ratio
quick question to find it.i have to turn the drive shaft by hands watching the rotation of the tire,or i can do it the other way turn the tire and watch the rotation of the shaft?
virtual_mage is offline
post #2 of 4 Old 04-04-2009, 11:22 AM
bunkrdfool
Jack up the rear end. Count driveshaft revolutions while rotating the tire. Turn the tire 2 complete rotations if your other tire remains stationary and does not rotate. Turn the tire 1 complete rotation if the other tire turns in the same direction. The number of times the driveshaft rotates equals the gear ratio. If the driveshaft rotates about 3x, the gear ratio is 3.07. If it rotates 3 3/4 turns, the gear ratio is 3.73. You can mark the driveshaft to help you count.
--Stolen from Wheelin98TJs FAQ thread in the TJ section
USAF Security Forces. Keeping your chair safe since 2009.
bunkrdfool is offline
post #3 of 4 Old 04-04-2009, 11:24 AM Thread Starter
virtual_mage
2009 JK Wrangler
thanks im 3.21 sadly time to a regear i guess lol
post #4 of 4 Old 04-04-2009, 11:35 AM
bunkrdfool
Well unless you plan on going with bigger than 33s i wouldnt worry for now. i had a stock x with 29s with the 3.21's and i stepped up to the 32's that come with the rubicon. i can still get up to 75-80, i dont use 6th gear much, but im not to worried about that.
How do I find out what rear axle and gear ratio I have Breacher631 YJ Wrangler Technical Forum 5 03-06-2009 05:20 PM
find gear ratio for rear axle timdastis TJ Wrangler Technical Forum 3 12-04-2008 08:42 AM
how do you find your axle ratio? jayinMS TJ Wrangler Technical Forum 3 01-25-2007 07:21 PM
where can i find my gear ratio and axle type baller88 TJ Wrangler Technical Forum 1 07-08-2004 03:22 PM
I cannot find my gear ratio! Maine-yj YJ Wrangler Technical Forum 5 03-04-2003 06:41 PM
