A few winch questions
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
| View Poll Results: Bang for the Buck, what's the best winch brand? | |||
| Warn |
23 | 57.50% |
| Smittybuilt |
11 | 27.50% |
| Ramsey |
2 | 5.00% |
| Mile Marker |
2 | 5.00% |
| T-Max |
0 | 0% |
| Champion (Costco) |
1 | 2.50% |
| SuperWinch |
1 | 2.50% |
| Voters: 40. You may not vote on this poll | |||
#1 | |
Ok, I've done some searching, I've combed the threads, and read countless posts. And I KNOW the information is on here somewhere, but quite frankly I'm tired of looking. So if someone could just answer a few questions for me, I'll be on my way.
A little background. My Rig is a '08 Rubicon. I have a Rugged Ridge XHD Modular Winch bumper. I've decided on the Smittybuilt XRC8 Winch (sorry, I know its a chinese, but its in my budget and I don't want to wheel without a winch). My questions are these: 1. Do I need a larger/better battery to run this winch? I don't believe I do from some of the reading I've done, but I can't get a definite answer. 2. Do I need a larger/better alternator to run this winch? 3. If yes to either 1. or 2., What are your recommendations? Thanks for any assistance you guys (gender neutral term) can provide me. --Chris
"The World was large, now it is small. It was lonely, now it is crowded. It was dark, now the lights are on. Some day the old will be new again. Keep your guns close but your sword closer. For one day Man will again fear the dark of the World." --The Zombie Prophet |
#2 |
In Omnia Paratus
Ive only had my winch 2 months tops.I did alot of research and asking around and this is what i got.
1. Your stock battery is okey as long as your engine is running while your winching. 2. No need to replace alternator. 3. I swapped my stock battery (has nothing to do with the winch) for an Optima.The red top is good enough but 4wp had a sale at the time so i got the yellow top. and i went with Mile Marker SEC 9500 ![]()
08 Jeep X Unlimited w/4" Rancho Sport lift rolling on 37-12.5-17 MTR Kevlar on Black ProComp Steelies 06 Jeep Rubicon w/5.5" Teraflex long arm + 1" body lift rolling on 35-12.5-17 BFG KM2 on 7031 ProComp Alloys |
#3 |
I got the Smittybilt XRC8, too, for $260 delivered. I'm not comfortable "relying" on it, since it is Chinese, (my own thoughts from experiences working in China, and having MOST chinese tools breaking down within 6 months) but for a budget rig, the price is awesome...and it's worked well both times I REALLY needed it!
Their -Smittybilt- customer relations is awesome, too. The male end of my controller (coupling) cracked in the freezing temps here, and Raymond sent me a replacement fast, without any fuss. If I had the "bucks", the "bang" would be with Warn, though. Heavy duty American made, like grandpa's tools --that work better today than they did in the '30's |
#4 |
I have only used warn and I will probably get a warn again.
I may get a smittybuilt for the rear because it is cheap though. |
#5 |
You did not list Superwinch. EPi 9.0 is good, has the lowest power draw.
As for the battery, stock is fine. I did upgrade mine to a Yellow Top, but it went bad after 18 months. Thanks to Sam's Club, they replaced it free even though warranty is good for 12 months.
2009 JK Rubicon. Auto, Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear; 11,000# Pull-Pal, Uniden 520XL CB with 3' FireStik Whip. Shrockworks Mid-width Front Bumper with Warn 9.5Ti -- Ordered 7/17/2009; Bumper Received 12/4/2009. Visit here to view my wheeling Pics: Moab-4/2006, 5/2008, 4/2009, 5/2011; Ouray-8/2007, Rubicon-9/2008. http://community.webshots.com/user/thunder1strike |
#6 |
The Superwinch EPI 9.0 that I have requires a battery with at least 440 CCA COLD CRANKING AMPS and an alternator that has an output of 60 AMPS. I believe the rubicon come with an alternator that outputs 140 and the factory battery has 660 cold cranking amps. Do I think the the OPTIMA is better? Yes. Do think you absolutely need it? Not unless your doing some serious wheeling.
#7 |
hmm the superwinch sounds like a pretty good winch for the price...
... I think the EPi is kind of ugly though ![]() |
#8 |
There are a few pictures of it on this website on the XHD bumper. If you do put it on a XHD bumper you have to grind the left inboard cornor of the bumper mount on your frame to get the mount holes for winch to line up. I would post a pick of mine but I am to lazy to start a photobucket account.
#9 |
After all the research I've done I went with a superwinch. Quality of the warn but at a fraction of the price.
#10 |
Gold Member
I almost went with the superwinch, but just before I bought it, I got a screaming deal on my Warn 9.5ti from a jeepforum member. My warn has served me well and I use it around the house regularly. I still have the factory battery and alternator and have not experienced any problems. When my factory battery goes out, I'll probably replace it with dual Optimas, because by that time I will have more electrical accessories.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, BFG AT TA KO 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Bilstein 5100 series shocks, 5.13 gears, Alpine IDA-X001, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650 http://www.jeepforum.com/forum/f129/hothead-headliner-1237401/ http://web.me.com/stevenpeltierjr/Living_It_Up/Welcome.html |
#11 |
Warn PowerPlant is my next winch, very awesome setup if you have used it from someone. Took us only ~15mins or less to air up 2 jeeps, one with beadlocks 37's and mine with 35's at 10psi. Very cool winch that I plan on getting even though it should be way out of my budget.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights. |
#12 |
XRC8 REPRESENT!!!
hasnt let me down... ![]()
Eat. Sleep. Jeep. |
#13 | |
#14 |
Jeeper for life ;)
Super winch
I have the Super winch LP8500 & it has worked flawlessly the three times I needed it . It is available in Canada at Canadian tire for 399.00 CDN so for value it`s a winner . Comes in at around 80lb with 90 somthing feet of 5/16 wire rope . I also swapped batt. for an Optima blue top starting & deap cycle batt.
#15 | |
Same here!
![]() Here's something interesting... If you pull back the braided cover over the wires, the insulation under says "Mile Marker". hmmmmmmm... So is the Smitty a rebranded Mile Marker?
for details and info on our JK's, check out http://n2rock.com His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list Hers: '08 X Red Rock, soft top, auto. Bunch of mods Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
