Fender inner liner problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Fender inner liner problems
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 07-11-2014, 02:29 PM   #1
tonkatrucksryan
tonkatrucksryan's Avatar
2014 JK Wrangler
I just had a shop put my smittybilt flat fender flares and I had them cut up my inner liners and put them in the best they could. My wife is still driving it home and the owner showed her all the caps. He was so unhappy with it that he didn't charge us. What should I do next I found that rugged ridge makes
Rugged Ridge All Terrain Wheel Well Liners.
http://www.quadratec.com/products/12510_5201_07.htm
Does anyone have any ideas or know what I should do
New build http://www.jeepforum.com/forum/f96/t...014-a-2020929/
26 Years USAF Retired 1MAY14
Past Jeeps:
04 TJ Rub,04TJ, 75CJ5, 88YJ
tonkatrucksryan is offline   Reply With Quote
Unread 07-11-2014, 02:52 PM   #2
tonkatrucksryan
2014 JK Wrangler
my wife is stuck behind an accident hope to have pics shortly sorry
Past Jeeps:
Unread 07-11-2014, 03:05 PM   #3
ferninaz
I suggest you go to MetalCloak and check out their inner fender liners.http://www.metalcloak.com/JK-Aluminu...lls-p/3290.htm
ferninaz is offline   Reply With Quote
Unread 07-11-2014, 07:04 PM   #4
tonkatrucksryan
2014 JK Wrangler
Rugged Ridge makes a set of inner liners I am thinking about. What do you think? They say that they are for their flat fenders but looks like it could me modified????
Look at all the gaps.... I didn't know the stock fender flare was attached to the inner liner. the company that worked on it and did their best and didn't even charge me for it
Past Jeeps:
Unread 07-12-2014, 01:30 PM   #5
222Doc
that is the best they could do? Why i will do it myself when ever i can.
My first attempt on mine and works great. took my time and always cut longer than short.
[URL=http://www.bullhead4wheelersinc.com[/URL]
222Doc is offline   Reply With Quote
Unread 07-12-2014, 02:53 PM   #6
tonkatrucksryan
2014 JK Wrangler
I ordered Rugged Ridge inner liners and Next Saturday it will be hopefully fixed!!!!
Past Jeeps:
Unread 07-13-2014, 09:08 AM   #7
HighandLow
Stay Frosty...
HighandLow's Avatar
2010 JK Wrangler
On my bushwackers and on 222doc's Nemises (?) there is a small inner lip to sort of tuck in the liner, you have to take your time and cut it just right to fit. It doesn't look like those smittybuilt flares have an inner lip. Maybe you could find a junkyard set of liners and try again?
2010 Rubicon, Auto, Stone White, 3"Synergy Coils, MetalCloak TB's and CA's, 35" Grabbers, 17" AEV Pintlers, ORF, PSC, JCR, PIAA, AEV, TeraFlex equipped...
HighandLow is online now   Reply With Quote
Unread 07-13-2014, 10:17 AM   #8
222Doc
fenders are poison spider narrows.
Yep you measure cut LONG I even used heat to reshaped mine to bend over the back edge to block water intrusion. the upper edge i did make tuck into it. I took my time and cut a little not a-lottel.
Those smitts say they are for a specific fender they make. hard to say how they will work with what looks like trimmed factory flairs?
Unread 07-13-2014, 10:47 AM   #9
JIMBOX
Sorry, but what you should do is--DOIT YOURSELF-
You can take all the time in the world and not pay a penny, as said-you always cut long and then the recut is forfit-
I used my stock liners and took my time--it's notta time trial-it's your jeep-
If someone else is doingit--then they're the ones that do the fitting--if it doesn't satisfy you--goto the bank !
Sorry, not much sympathy, but I'm not known for that-
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote
