factory sub??? - JeepForum.com
post #1 of 7 Old 07-13-2013, 10:37 AM Thread Starter
broken-wrangler
factory sub???
so I just bought a JKUR and it has the alpine sub in the back. I know that with the searching I have done, the sub is pretty much worthless, but is there a way to bridge the sub across the ohms and make it bump the voltage it is receiving? i would rather not purchase a new replacement sub at the moment but im trying to see if i can manage to get this thing to bump just a little harder. It does seem like it could handle much more than what it is seeing right now.
Josh Ashley
broken-wrangler is offline
post #2 of 7 Old 07-13-2013, 10:41 AM
Wavedatya
2010 JK Wrangler
My 2010 with Infiniti sounds great! Goo enough for my needs. I have the bass at -4 and it still pumps pretty good. Maybe yours isn't working
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #3 of 7 Old 07-13-2013, 10:55 AM Thread Starter
broken-wrangler
No it works. It's the the alpine 8inch it's just sad
Josh Ashley
post #4 of 7 Old 07-13-2013, 11:16 AM
COLOUXJ
2010 JK Wrangler
Originally Posted by broken-wrangler View Post
sis there a way to bridge the sub across the ohms and make it bump the voltage it is receiving?.
How the hell do you bridge ohms? If you do not know what ohms are I would not mess with anything involving electricity in your jeep.
There are several threads around here about upgrading the sound system on the JK's. Use the search bar to look for it.
COLOUXJ is offline
post #5 of 7 Old 07-13-2013, 11:25 AM Thread Starter
broken-wrangler
Yes I know what ohms are. You can take a 4 ohm sub and take it down to two ohms by bridging either side.
Josh Ashley
post #6 of 7 Old 07-13-2013, 12:45 PM
Demp
That is a simplified idea of it, yes. To nitpick your original question you don't increase voltage by changing resistance, you change the current flow :P
The factory sub is a 2ohm DVC. I would suspect it can handle more power but the problem is the factory amp. The amp has two channels that feed the sub's two coils. If you bridge them and run off one channel at 1ohm you will most likely destroy the factory amp. If you tried to bridge the channels you are likely to destroy it as well.
The factory amp, being OEM, doesn't have any real published stats on bridgability or ohm stability. The sub's power rating isn't published either for the same reasons. Top it off with the fact the factory amp rolls off the very low end (Can't hear under 30hz when I had my factory setup) and you have quite a few things stacked against good bass.
The easiest solution is to either gut the factory system or get something that does line level conversion, a bass restorer, and a new amp/sub.
Demp is offline
post #7 of 7 Old 07-13-2013, 08:40 PM Thread Starter
broken-wrangler
I have a sub and amp but the subs a 10inch so I'll have to get a different sub. I was just hoping to get more out of this one since it doesn't really look that bad of a sub.
Josh Ashley
