Extended Rear Swaybar Links Needed for OME? - JeepForum.com
post #1 of 6 Old 02-01-2010, 02:41 PM Thread Starter
kubwa_jim
If I get the OME 2in lift with the heavy springs and long travel shocks for my four door, do I need extended rear sway bar links? I'm getting longer brake lines, but I wasn't sure if I had to have the links as well.
Don't look at me, your rights were violated before I ever got here!!
kubwa_jim is offline
post #2 of 6 Old 02-01-2010, 05:30 PM
ncb
You will need longer links front and rear. You want the sway bar ends to be near parallel with the ground.
ncb is offline
post #3 of 6 Old 02-01-2010, 05:32 PM
mc2065
2009 JK Wrangler
Based on what I've read here, swaybars need to be parallel to the ground +/- 5 degrees. So for $80 I bought adj.'s from Northridge and moved the rears to the front and all is well now. I know the Quadratec catalog said I did not need them but it made me feel better to put them on.
mc
OME lift 619/617, JKS front trackbar & rear trackbar & brace, Procomp 7005 & 285/70/17 Duratracs, AEV Procal, Poly Perf. Frt LCA's, Rigid D2's, Vision X Solstice on rear
mc2065 is offline
post #4 of 6 Old 02-01-2010, 10:40 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I cut the rears in half, found some good strong steel tube that had an ID that was real close to the OD of the rear links, cut the tube to the proper length to level the bar and welded them up. After a coat of paint, doing fine after two years...cost, about 10 bucks as I recall....
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 6 Old 02-02-2010, 12:25 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Thats what I am planing on doing except I'm going to move the rears to the front and cut and extend the fronts for the rear
Jim
JLC08JK is offline
post #6 of 6 Old 02-02-2010, 07:26 PM Thread Starter
kubwa_jim
Those are good ideas, thanks.
What rear swaybar links to buy? BigMikeATL JK Wrangler Technical Forum 20 11-03-2009 06:12 PM
rear swaybar links outlawjosywales TJ Wrangler Technical Forum 1 07-16-2009 06:53 PM
rear sway bar extended links safarimike TJ Wrangler Technical Forum 2 07-07-2008 10:04 AM
Extended Rear Swaybar Connects Needed? MarineSniper TJ Wrangler Technical Forum 6 03-08-2008 12:02 PM
Rear extended Sway Bar links... CHRRRIS TJ Wrangler Technical Forum 7 04-22-2007 01:40 PM
