Exhaust manifold.....hard to replace??? - JeepForum.com
post #1 of 34 Old 01-24-2012, 09:19 PM Thread Starter
havasu1
2015 JK Wrangler
Well my driver side exhaust manifold cracked. Are they hard to replace. Or should I say, will the bolts snap? I don't think the manifold would be hard to replace, I just don't want to mess with broken bolts (a jeep staple for sure). Shop wants$350.00 to replace one side, seems like a lot of doe for a $100.00 worth of parts.
On a side note, are there exhaust manifold that I should buy and do it myself (besides the RIPP ones, very pricey as nice as they are).
havasu1 is offline
post #2 of 34 Old 01-24-2012, 09:50 PM
DrHolliday
2011 JK Wrangler
I would do it yourself, just soak the bolts in WD-40 or PB blaster over night. And have a ride available to take you to get spare bolts if one breaks. I'd think the manifold to exhaust pipe would have the best chance of snapping on you.
Don't use 12 pt sockets, only 6 pt so you don't risk rounding off the heads.
2011 JK Rubicon 2 door 6-speed manual, 3.5" Rock Krawler Suspension lift, 1.25" Daystar body lift, 40x13.50R17 Nitto Mud Grapplers
DrHolliday is offline
post #3 of 34 Old 01-25-2012, 04:04 AM
jabsther
2010 JK Wrangler
I changed the ZJ I had before. Bolts came off with no problem. Used wire brush to get large rust off the studs/nuts and sprayed PB Blaster on it for a week.
jabsther is offline
post #4 of 34 Old 01-25-2012, 06:17 AM
JemLT1YJ
2011 JK Wrangler
Some stuff ive found that works better then anything... Loctite freeze and release. You spray the bolt/nut for 5-10 seconds then let it sit for a little over a min and they come right off. Shock freezes the bolt/rust to crack it and let the penetrating oil into it. Very neat stuff. Using it on my bro in laws 97 f150, doin head gaskets. Been very useful never seen a vehicle so rusted and i work on a 90 xj, and 89 yj...
Edit: heres a link http://www.loctitefreezeandrelease.com/
JemLT1YJ is offline
post #5 of 34 Old 01-25-2012, 08:34 AM Thread Starter
havasu1
2015 JK Wrangler
thanks for the input. I'll try that locktite product. Any headers you recommend? Are they all pretty much the same. Just go get some off Rockauto?
havasu1 is offline
post #6 of 34 Old 01-25-2012, 08:44 AM
Alaska-HWY JK
Had mine replaced under warranty just before it ran out. One bolt broke and they couldn't get at it to drill and easy out so they had to pull the head. Top end gaskets were back ordered for a week. Long story short I'm glad I didn't do that one in the driveway. On a side note the Jeep runs a lot better now and on long road trips I'm getting the same mpg with 37's as I was when it was stock many years ago.
Alaska-HWY JK is offline
post #7 of 34 Old 01-25-2012, 09:04 AM
Cirruslydakota
^^^ Another vote for the loctite freeze penetrating oil. That stuff is easily the best stuff ive ever used.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #8 of 34 Old 01-25-2012, 09:10 AM Thread Starter
havasu1
2015 JK Wrangler
Is it worth going to the Gibson headers or just getting some stock ones
havasu1 is offline
post #9 of 34 Old 01-25-2012, 11:19 AM
Prot
Prot's Avatar
2014 JK Wrangler
I would be worried that the stock replacement would crack like the original.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is online now
post #10 of 34 Old 01-25-2012, 11:35 AM
utlax18
Out curiosity, how did you find out your exhaust manifold was cracked? I have heard that you can hear a tapping sound. My JK as 55K miles and am smelling a little exhaust in the cabin when I fire it up, but not when I am driving down the road. I don'thear a tapping sound, but still wondering if I have acrack somewhere if I am smelling a bit of exhaust.
Cheers!
utlax18 is offline
post #11 of 34 Old 01-25-2012, 02:51 PM
spookylynx
2010 JK Wrangler
If your pulling them off anyway, you might as well upgrade to a nice headder. I think I'm going to do mine in the spring, with RIPP Mods long tube headder. Bit pricey but a really sweet setup.
spookylynx is offline
post #12 of 34 Old 01-25-2012, 08:11 PM Thread Starter
havasu1
2015 JK Wrangler
yeah, they are pricey. That's whats keeping me away. I have other mods I want to do first such as upgrade my lift. I'll see how this one goes. Stock replacements are pretty cheap. $90 bucks or so.
havasu1 is offline
post #13 of 34 Old 01-25-2012, 08:13 PM Thread Starter
havasu1
2015 JK Wrangler
Cheers!
I could actually see the crack just below the heat shield. What happens over time is you get a ticking sound, almost sounds like a lifter is clicking. Anyway, it happens when you start it up cold, it makes a ticking noise that in my case, would go away when at temp. But it is getting louder as I think the crack is getting worse.
havasu1 is offline
post #14 of 34 Old 01-27-2012, 02:56 PM
spookylynx
2010 JK Wrangler
I totally understand prioritizing mods, but I think Gibson or Rustys make a nice short tube hedder that is'nt too expensive, but if I had to choose between suspension and hedders, I'd choose suspension also.
post #15 of 34 Old 01-27-2012, 03:11 PM
GPV
Check this out to aid in removing rusty bolts:
http://grassrootsmotorsports.com/for...t/13650/page1/
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
About to replace my exhaust manifold--should I go further? Bronze YJ Wrangler Technical Forum 14 10-07-2011 11:53 AM
Need to replace my exhaust manifold... AnonymousD YJ Wrangler Technical Forum 4 09-22-2011 07:23 AM
Cost to replace exhaust manifold? shaggy105 TJ Wrangler Technical Forum 3 04-03-2009 02:17 PM
How to replace exhaust manifold BChamberlin TJ Wrangler Technical Forum 9 07-23-2007 10:34 AM
how difficult to replace exhaust manifold? Bot YJ Wrangler Technical Forum 7 10-01-2005 12:50 AM
