05-06-2012, 01:08 AM
#1
Yesterday I had a really “interesting” experience with my JK (08 sahara)… while taking a turn (not a sharp one and with not more than 60 Km/h) the ESP light came on and the car started braking in order to “get grip” when I got back on the highway the ESP light was on (as the ESP was disabled). Well I ignored it, enable ESP again and said to myself that probably the car “slipped” due to water or something on the road that I didn’t see…
Next turn exactly the same thing,  tires, shocks and springs are brand new (3’’ lift), it has just been serviced, no water or anything else on the road… I don’t know if it is a pre-DW behavior but does anyone else experience that?
And it only happened on turns; intentionally I went over a small bump with 110-120 km/h but no DW… went home checked bolts and they all look tight enough…
Any ideas?
Thanks for the help
05-06-2012, 01:11 AM
#2
The Voice Of Reason
I had this problem with my 2007 and it ended up being a bad wheel sensor according to a shop.
05-06-2012, 01:12 AM
#3
Sarcastic Fantastic
New lift? ESP trouble? You need to do an alignment on your front. Check out the JK FAQ.
--/ 2011 Jeep Wrangler JKU - The White Coyote /--
Support our Jeep community and actively participate in our threads! Use thumbs up for good & helpful posts!
My Build: http://www.jeepforum.com/forum/f96/c...hread-1339466/
Teraflex - General Tire - Poison Spyder - AEV - Warn - Yukon - ARB - Aussie - Motive Gear - Rigid LED - Procomp - Synergy - EVO - Viair - Cobra - Firestik
Poison Spyder and AEV had a baby: the only JKU with a Poison Spyder bumper and an AEV Tire Carrier!
05-06-2012, 01:19 AM
#4
I had an alignment! and not for the stock JK's, I gave it for a wheel alignment and the guy added on the laser measurements in front of me the 3'' additional height...
so i don't think it's that... thanks for the answer though!
as for the sensor... it happened on different direction turns... is it possible to lose both front sensors?
thanks again
05-06-2012, 01:20 AM
#5
Sarcastic Fantastic
05-06-2012, 01:42 AM
#6
thanks again
The steering wheel alignment. If the steering wheel is not straight with the wheels, it will trip your ESP and cause other problems. I tested this when I lifted mine just to see what would happen and sure enough, the ESP came on and the Jeep started pulling to the right, hard. Neighbors thought I was drunk
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
05-06-2012, 01:43 AM
#7
as i said all that have been done electronically
should i start searching sensors, loose bolts (although i did that also) or there is something that i am missing??..
05-06-2012, 05:20 AM
#8
Gold Member
Is your steering wheel perfectly centered when your tires are straight?
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, Goodyear Duratrac 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Front Rancho 9000 shocks, Rear Bilstein 5100 series shocks, 5.13 gears, Kenwood DNX9990HD, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650
05-06-2012, 05:30 AM
#9
well yes... with the usual small "play"... but yes it is
05-06-2012, 07:42 AM
#10
Virtually always caused by axle misalignment side to side, which affects the steering wheel & clock spring relationship. A simple way to determine your axle centering is to use a tape measure and measure the distance between the outer side of the frame and the inside of the tires. Pick a spot that's the same on both sides, no brackets, etc. to corrupt the measurement. Same with the tires, move the rig so you won't be measuring lettering, side lugs and otehr junk. The measurements should be within 1/8" side to side. Measure and corect the rear first, then do the front. After you get the rig centerd over the axles, adjust the steering wheel to be perfectly centered on a flat, uncrowned road. For measuring points I use a spot on the frame, right under the rear the front spring bucket. In the rear I use a spot right in front of the bump stop. These spots are identical side to side, with no interference. There are other ways to do the measurements but this is the simplest and will get you close enough.
05-07-2012, 12:03 AM
#11
Thanks for that! really appreciated
I will try to check and if that doesn't fix the problem I will move to the sensors.
05-08-2012, 12:11 AM
#12
checked that with the help of a friend... everything seems ok and that is the troubling part... maybe it is the ABS/ESP sensors but i don't know any other way to check them except from taking it to the dealer...
additionally it hasn't done it since...
