esp issue after lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > esp issue after lift
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 08-02-2012, 09:29 PM   #1
MHjk
2011 JK Wrangler
just did a 4 inch to the 2011 jk. the steering wheel is off centre and the esp is kicking in and making it difficult to drive. I have researched and saw that it may be activating due to the steering wheel off centre. I have it booked in for wheels, tires and alignment wednesday. the traction light went on after 5 minutes of driving and the system shut off which i was ok with but just as i was driving home from the store the system reactivated itself and now its difficult to drive again. How do i shut off the system in the mean time on the 2011?
MHjk is offline   Reply With Quote
Unread 08-02-2012, 09:34 PM   #2
saddis
2009 JK Wrangler
You have to center the streering wheel on a JK before you drive it after you lift it. The instuctions should have told you this. The esp will not go off until this is done. All you need is a 15mm socket and a few mins of your time to fix this yourself. You don't have to wait till the alignment is done to fix this problem.
Steven
saddis is offline   Reply With Quote
Unread 08-02-2012, 09:38 PM   #3
MHjk
2011 JK Wrangler
I should have done it the other night when we put it in, i guess i\ll have to make time tomorrow for this
Unread 08-02-2012, 09:42 PM   #4
saddis
2009 JK Wrangler
Takes a little trail and error if your alone. Since you put a 4" lift on turn the adjuster on the drag link a few rotations then test drive. If still not strait repeat as needded.
Steven
Unread 08-02-2012, 09:46 PM   #5
MHjk
2011 JK Wrangler
ok thanks for the advice. I'll prob just drive it into the shop tomorrow instead of the work truck and get one of the guys to give me a hand to get it right the first time.
Unread 08-04-2012, 08:28 PM   #6
agenbroad99
Just turn the esp off for real. it is a pain in the butt. much better turned off and you wont have to worry about the steering if it goes off while wheeling or anything.
2008 JKU Sahara Banks Monster and Ram Air, 6SPD, 4.88 G2 Gears, PureJeep Rocker Guards, 315/75/16 Goodyear MT/Rs, Mickey Thompson Classic II, Teraflex 3" with Bilsteins, Rough Country Bumper with Engo 10K install, oh yeah and Flat Fenders.
[url]http://www.youtube.com/watch?v=whKFbphWpvY&feature=player_embedded[/url]
agenbroad99 is offline   Reply With Quote
