ESP BAS - Warning Light - JeepForum.com
post #1 of 17 Old 09-24-2007, 08:05 AM Thread Starter
Grant211
I was pulling into the parking lot and the ESP BAS warning light came on. What causes that warning light to come on? According to the service manual i need to take it to the dealership. Obviously, I will. I am just curious why it came on.
The funny thing is... as i pulled into the parking lot it came on. I pulled into a parking spot and turned off the jeep. Went into the store, came out, started up the jeep and the light did not come on.
This has happened like three times in the past month. I don't drive like a maniac nor have I done any real hardcore off roading.
any ideas/help would be greatly appreciated.
2007 JK Unlimited Sahara
2.5" Teraflex Budget Boost, 1" MORE Body Lift, KC Slimlights, ProComp 7047 Wheels, 305x65x18 (34's) BFG AT KO's, Airraid CAI, Riddler Differential Covers, Headlight & Taillight guards, etc...
Grant211 is offline
post #2 of 17 Old 09-24-2007, 09:16 AM
rac-jeep
Yeah. Fairly common issue. Several threads on the topic. There is apparently a "flash" that can help. Bottom line is the system seems to be too sensitive.
Here is a thread on the topic:
http://www.jeepforum.com/forum/f96/esp-issue-poll-who-has-who-has-not-455016/
rac-jeep is offline
post #3 of 17 Old 09-24-2007, 09:42 AM
sightor
I am having this issue at 2400 miles. Lite stays on all the time. Took to dealer. They flashed computer and lite went out. Drove it, lite came back on. Flashed computer but lite stayed on. Dealer has ordered new computer -- I am waiting!
sightor is offline
post #4 of 17 Old 09-24-2007, 10:06 AM Thread Starter
Grant211
thanks for the replys...
I've never had so many issues with any other vehicle I have purchased. I am starting to regret getting this jeep
Grant211 is offline
post #5 of 17 Old 09-24-2007, 06:55 PM
RenoosRemoob
We experienced that issue once back in June. I was driving back to work after lunch when the engine bogged way down and I noticed that the ESP/BAS warning lights came on. I looked it up in the manual and it said to take it in to the dealership so I did.
They said they could not duplicate the ESP/BAS situation and said the computer did not disclose anything nor could they duplicate the leak or find any history of the flash issue on the computer. We picked it up that evening at no charge and it has not happened since.
RenoosRemoob is offline
post #6 of 17 Old 09-24-2007, 07:32 PM
Prot
Prot's Avatar
2014 JK Wrangler
FWIW, I have not had one single issue with mine. I even started specifically looking for anything mentioned on this forum and I can't find anything wrong. The only thing is the dashboard scratches too easily, but other than that, no esp, no paint issues, no misalligned doors, no leaking hard tops, no leaking softop, no wind whistles near the windshield, no dome light rattling, no flashing lights and gauges going crazy, no issues with the brakes, never been stranded, horn has always worked properly, the shifter on the automatic transmission has never gotten stuck. A rock hasn't even hit the windshield.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #7 of 17 Old 09-24-2007, 07:35 PM
RickRJeep
I guess it's just blind luck, then. That or karma.... Who knows.
Silver 07 Unlimited Rubi, bone stock (company car)
Wanting Black 08 Rubi 2dr
RickRJeep is offline
post #8 of 17 Old 09-24-2007, 08:12 PM
Warlord2
its just so stupid that jeep wont do anything about it or even accept it to be a faulty computer chip, they rather blame the lift kit even though stock jeeps are doing it as well.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #9 of 17 Old 09-28-2007, 07:05 PM
sightor
UPDATE: Took JK in today for new parts installation. They worked on it for 4 hours downloading the new computer module. Problem still remains, so now they are ordering parts for inside steering wheel. I suspect they really don't know what's wrong -- just replace a part and see if that does it. Starting to get a little frustrated. Has anyone had this problem and had it successfully corrected??
sightor is offline
post #10 of 17 Old 09-29-2007, 12:12 AM
viking81
I had same problem with mine. I was told that lift kit or tire size does not plays any role with this issue. It is a factory issue. They replaced the sensors and now it stoped. i still have ongoing problem with steering.
viking81 is offline
post #11 of 17 Old 09-29-2007, 06:31 AM
wriver82
wriver82's Avatar
Had the same problem over the last weekend, brought it in and now it seems to be okay, one note on the reflash procedure, jeeps with the auto sway bar disconnects has a different procedure than the ones without, maybe you should check to see if they did it that way or not.
wriver82 is offline
post #12 of 17 Old 09-29-2007, 11:40 AM
merlinTec
merlinTec's Avatar
Hi
Think you are getting confused with the recalls and TSB. The G25 (stalling flash) has a different procedure for JK’s with the disconnecting arms. The F50 recall for the ABS and the TSB 08-007-07 for the ESP light doesn’t.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #13 of 17 Old 08-12-2013, 12:47 PM
cigarsnjeep
2007 Wrangler
I have 145,000 miles on my 2007 and never had a problem. Driving in high temperatures - above 95 seems to trip the sensors on mine. I just pull over to the side of the road and restart and it seems to clear it out. I was wondering if has anything to do with the brake pads I had put in about 15,000 miles ago but apparently that may not be the case. I do not know how good of brake pads I had put in but was not sure if the heat and quality of pad had something to do with it.
cigarsnjeep is offline
post #14 of 17 Old 08-12-2013, 02:48 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
My guess is that you have a cable/connection problem at one of the wheels when the brakes were installed. Might see if there is a code.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #15 of 17 Old 10-03-2013, 05:35 PM
cigarsnjeep
I went to a Pep Boys and one of the guys there works exclusively on Jeeps. I asked him about this problem and he suggested that I remove the air cleaner and spray some carburetor / throttle body cleaner in the intake while it is running and then use a rag to clean out the carbon after turning it off. I did this and so far I have not had a problem. He said that the carbon build up can cause it to think the throttle is stuck which can cause it to shut down. It has been about 3,000 miles and no issues but we will see. I hope this helps someone.
Esp/bas Warning Light On. victory red JK Wrangler Technical Forum 0 03-25-2009 09:15 AM
Warning Light bcoffman2@allte JK Wrangler Technical Forum 21 12-23-2008 11:21 AM
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 09:29 AM
Airbag Warning Light Bigmotorjammer TJ Wrangler Technical Forum 2 10-08-2007 10:12 PM
Warning light magna YJ Wrangler Technical Forum 1 07-03-2001 01:23 PM
