ESP BAS, ESP, and ABS Lights on - JeepForum.com
post #1 of 13 Old 12-23-2008, 06:30 AM Thread Starter
SkampDiddy
Hey:
Has anyone ever had these 3 lights come on at once? I can get the ESP light off when I click the button a couple of times, but the ESP BAS light and ABS light stay on. I was using my 4 Wheel Drive yesterday to get through some deep snow and they have been on ever since. Does anyone know if this is a serious problem? Any help would be great, thanks.
Skamp
SkampDiddy is offline
post #2 of 13 Old 12-23-2008, 06:41 AM
devilsfiddle
reply
If it stayed on you should take it to the dealer. My ESP light and traction control light was staying on and the dealer needed to replace the clock spring, which was under warranty.
JK 08 X
devilsfiddle is offline
post #3 of 13 Old 12-23-2008, 06:54 AM
Northsidejeepin
This can also be a steering issue that dealer must correct.
Northsidejeepin is offline
post #4 of 13 Old 12-23-2008, 08:16 AM
OregonVette
Yep, fairly common from what I understand. Take it back to the dealer ( mine was a cam-sensor) and a quick reflash and you're on your way.
Easy enough and not a biggie
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
post #5 of 13 Old 12-23-2008, 08:22 AM Thread Starter
SkampDiddy
Sounds good, thanks for the info everyone!
post #6 of 13 Old 12-24-2008, 11:32 AM
faticone
2009 JK Wrangler
wheel speed sensor -- the dealer replaced mine and i havnt had a problem since
check http://www.jeepforum.com/forum/f96/damp-conditions-picture-645197/
2009 Jeep Wrangler X Black
Wentworth Institute of Technology
faticone is offline
post #7 of 13 Old 12-24-2008, 12:39 PM
DougieFresh
Mine does the same when it gets really wet, like water crossings usually. But then they go off when it dries out.
2008 2dr JK
Mod List (So far)
OME HD Lift with NitroCharger shocks. JKS front and rear adjustable trackbars. 33" Toyo Open Country MT's on 18" XD Rockstars. JKS Quicker Disco's. RockHard 4x4 Oil Pan Skid. Shrockworks Rock Sliders. Woods SS relocation bracket & evap relocation bracket. sPod switch panel. Tuffy Security Cover
-Drive it like you stole it-
DougieFresh is offline
post #8 of 13 Old 12-27-2008, 10:56 AM
planman
Thanks to all Mod erators
planman's Avatar
check http://www.jeepforum.com/forum/showthread.php?t=645197
X2
Mine was a wheel speed sensor. Replaced under warranty.
planman is offline
post #9 of 13 Old 12-27-2008, 11:07 AM
BRICKTOP2
Unhingd PigFeedng Gangstr
BRICKTOP2's Avatar
Who do I gotta talk to about getting my dash to light up like a Christmas tree?! That's some festive s#!+ right there!
"Tightening the nut behind the wheel is the most cost effective way to improve the performance of any vehicle."
JK Build Thread
TJ Tub Trailer
BRICKTOP2 is offline
post #10 of 13 Old 02-23-2010, 02:42 PM
J98M04
Yeah i had same problem took it to the dealer...it was the abs speed sensor $286 dollars later everything ok
J98M04 is offline
post #11 of 13 Old 07-25-2015, 03:07 PM
Ang2752
2008 LJ Wrangler
Abs,esp bas lights
Lights came on all at one time 2 days ago and still haven't went off. Today driving on the interstate had cruise control on then it just kicked off?? Please help not sure if it's just a sensor or a real big problem. Thanks
Ang2752 is offline
post #12 of 13 Old 07-25-2015, 03:37 PM
rich6700
Cruise control deactivates when abs lights are on.
rich6700 is offline
post #13 of 13 Old 07-25-2015, 03:41 PM
Ang2752
2008 LJ Wrangler
These lights came on probably last year when I was driving and turned a little to sharp and traction control light, ESP BAS and ABS lighta all came on. And probably a day later finally turned off. Well this time they're not ! No new noises or driving different
Ang2752 is offline
dash lights just went out, along with running lights, and tail lights. what happened bortz1892 TJ Wrangler Technical Forum 50 09-04-2016 05:33 AM
Area lights = Fog lights? Directional lights = driving lights? Marn TJ Wrangler Technical Forum 2 07-10-2006 01:46 AM
Silvian Star Headlight w/ Stock Fog Lights / Halogen Off Road Lights mferrari TJ Wrangler Technical Forum 3 03-29-2006 07:37 PM
brake lights, ok; tail lights/side markers/turn signals not.... help? LoneJeeper TJ Wrangler Technical Forum 2 09-12-2005 08:18 PM
no lights, no lights, no lights !!!!!! {problem found} renegade0351 YJ Wrangler Technical Forum 10 03-06-2002 10:21 PM
